Correct part # - Club Lexus Forums
Go Back   Club Lexus Forums > Lexus Model Forums > GS Models > GS - Second Generation
Sign in using an external account
Register Forgot Password?
Correct part #
Thread Tools Search this Thread
Old 11-02-09, 11:40 AM   #1
solotallbo
Trader Score: (0)
Default Correct part #
Hi, I want to give the door actuator a DIY, however, I cant determine what is the correct part # for the Mabuchi motor for my 2003 GS. I see both FC-280PC-22125 and FC 280PT 22125. Can you help me in choosing the right one?
Thanks
This ad is not displayed to registered members.
Register your free account today and become a member on Club Lexus!
solotallbo is offline   Reply With Quote
Old 11-02-09, 12:42 PM   #2
MattVR4
Trader Score: (0)
You might want to check out this thread
http://www.clublexus.com/forums/gs-s...ators-diy.html
I purchased it from tag16c on ebay. I typed in FC 280PT-22125 but i believe tag16c had a different # but it is like a new replacement # that would fit. Just go to ebay and type in FC 280PT-22125 and if you see the seller's name is tag16c it should say something like a replacement part # for FC 280PT-22125.
MattVR4 is offline   Reply With Quote
Old 11-02-09, 12:47 PM   #3
MattVR4
Trader Score: (0)
Just checked my receipt. The Manufacturer Part Number: FC 280PT 22125; and Interchange Part Number: FC 280PC 22125. It means both PT or PC should be the same b/c I had the PC one and it works on my car.
Old 11-02-09, 12:57 PM   #4
solotallbo
Trader Score: (0)
Thanks for the 411....just a couple questions? did you do the replacement yourself? and if so, on a scale of 1-10 (10 most difficult) how would you rate this job?
Thanks
Old 11-02-09, 01:41 PM   #5
MattVR4
Trader Score: (0)
Yeah I replaced it myself not hard at all. I would rate this as 1 but then I am pretty good with little thing to all the way replacing turbo, fuel pump .. etc. on my other cars. The hardest part is probably cutting the box open and replacing the little motor inside. Actually, it is not hard but very time consuming.
Old 11-02-09, 03:34 PM   #6
Trav7414
Trader Score: (0)
I just replaced my driver side this past weekend. The hardest part is cutting the freaking plastic cover and taking the metal part from the tip out from the old motor to put it into the new one.
Trav7414 is offline   Reply With Quote
Old 11-02-09, 05:24 PM   #7
solotallbo
Trader Score: (0)
What did you guys use to open the plastic part?
Old 11-02-09, 05:36 PM   #8
lexus ASM
Trader Score: (0)
lexus ASM's Avatar
Quote:
Originally Posted by MattVR4 View Post
Yeah I replaced it myself not hard at all. The hardest part is probably cutting the box open and replacing the little motor inside. Actually, it is not hard but very time consuming.
^^^^True Story!!!
__________________
Yup, theres a TSB for that.
lexus ASM is offline   Reply With Quote
Old 11-02-09, 07:14 PM   #9
MattVR4
Trader Score: (0)
I used a box/carpet cutter ... please be VERY careful and don't cut your fingers, take it slow and easy
Old 11-03-09, 10:52 AM   #10
JiBBeL
Trader Score: (2)
I used a steak knife FTW
__________________
2008 Lexus RX350
2007 Audi S8
JiBBeL is offline   Reply With Quote
Old 11-05-09, 02:06 PM   #11
solotallbo
Trader Score: (0)
Hi forum.
Need some help big time. I proceeded to change the actuator motor today and had to pause because i got to a point that i need some assistance on.
I got to the old motor and upon pulling it out I noticed a black torx looking item on the end of the motor. I could not remove this item. I used a hammer, put it in a vise grip and no luck. Anyone got a suggestion, it was so frustrating being so close but so far.
Additionally, the motor that i bought has a little brass ring around it. Looks just like the images posted by TRD11 in the forum. Should this be removed? How is it removed? Should I have ordered the one w/o the brass item/ring?
Thanks CL
Old 11-05-09, 05:52 PM   #12
a#'z
Trader Score: (0)
a#'z's Avatar
Send a message via AIM to a#'z
Use a heat gun, while pulling it out at the same time, that's what i did.
a#'z is offline   Reply With Quote
Old 11-06-09, 06:15 AM   #13
Trav7414
Trader Score: (0)
I used a dremel tool to cut it. First I was using the box cutter, but I don't have that patient like some of you guys here, so I just use the dremel tool and cut it out and then I use the glue gun to put them together. Dunno how long it hold hold, but as of now it works like a champ . 4 extra spare motors waiting to take turn lol.
Old 11-06-09, 01:47 PM   #14
solotallbo
Trader Score: (0)
Thanks to all you geniuses on the forum...you all just saved me over $1,000 by doing a DIY on the actuator. Nice job!!!!
Old 11-06-09, 03:41 PM   #15
Trav7414
Trader Score: (0)
Quote:
We're all just guinea pig to our own car just like you my friend
Similar Threads
Thread Thread Starter Forum Replies Last Post
RX300: DIY door lock actuator fix write-up 2002RX300 RX - First Generation 245 06-28-15 02:54 PM
Door Lock Acutuators DIY ??? TRD911 GS - Second Generation 1114 06-25-15 12:39 AM
RX330 Door Lock Actuator DIY JamesInJax RX - Second Generation 10 12-22-14 12:54 PM
door lock actuator Mabuchi motor TTurboPimp LS430 9 02-15-14 02:54 PM
Cheap Fix for Door Lock Actuator Problem wes61 LS460, LS460L and LS600h 1 06-09-13 02:47 PM
Tags
280pc22125, 280pt22125, actuator, brass, door, fc, fc280pc22125, fc280pt22125, lexus, motor, rx300, tip
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Join ClubLexus
Copyright © 2000-2015 Internet Brands, Inc. All Rights Reserved
Privacy Policy | Disclaimer | Terms of Use | JOBS
Get all contact info
