This Forum is Sponsored By:
Go Back   Club Lexus Forums > Lexus Model Forums > GS Models > GS - Second Generation
Thread Tools Display Modes
Old 11-02-09, 02:50 PM   #1
LudeNsoL
Trader Score: (0)
LudeNsoL's Avatar
thanks and yes I would like some more pics please. Also this is on a 300 right?
__________________
LudeNsoL is online now   Reply With Quote
Old 11-02-09, 03:49 PM   #2
speedaddic
Trader Score: (1)
speedaddic's Avatar
from the pics, its a gs400
__________________
394 whp 337tq supercharged GS400
don't buy fake ...stop the copy
speedaddic is offline   Reply With Quote
Old 11-02-09, 05:10 PM   #3
Clifton
Trader Score: (0)
I don't have any for the 300, sorry. If the JZ's are anything like the ZZ engines it will be easy to get to. If you can't find it on there, I downloaded the whole FSM in pdf forum for $20. Covers everything on the car. I was looking for the site but can't find it. I know I found the link on CL though.
Clifton is offline   Reply With Quote
Old 11-02-09, 05:22 PM   #4
lexus ASM
Trader Score: (0)
lexus ASM's Avatar
I'd like to know once you perform this screen cleaning if the code goes away. My understanding is that there is a pressure switch that goes bad causing this problem, I would think if that oil control valve went bad you would have bigger problems.
__________________
The 90k died the day the timing chain arrived
The rattles began when cars stopped coming from Japan
lexus ASM is offline   Reply With Quote
Old 11-02-09, 07:18 PM   #5
Clifton
Trader Score: (0)
There isn't a pressure sensor, there is a trigger wheel in the center of the intake cams. If the cam isn't where it should be when it should be the code will be thrown. If it is too slow it will through a code. The oil control valve may still be getting enough oil, just not the volume so it has a delay. Same with 02 sensors, when they get old they get slow and then throw code even though they are still producing the proper voltage for the 02 content.
Old 11-02-09, 10:51 PM   #6
TxLexus400
Trader Score: (0)
TxLexus400's Avatar
so i had this problem and the other day i did a very thoro oil change and seafoam cleaner as well. i have been driving my car the past 2 days and so far no more cel. so hopefully all is good and back to normal.
TxLexus400 is offline   Reply With Quote
Old 11-03-09, 08:47 PM   #7
spliffygs4
Trader Score: (0)
hey clifton thanks alot for the info, im gonna change the ocv's this weekend and i will let you guys know how it works out for me.
spliffygs4 is offline   Reply With Quote
Old 11-04-09, 05:39 AM   #8
Clifton
Trader Score: (0)
Quote:
I don't know your exact plans but I wouldn't replace them. The ocv's are pretty simple and not much can go wrong with them. I took mine out and cleaned them first then a month later ended up doing the filters. The ocv's get a lot of caked up oil crude too but the screens are really fine, kind of like a screen for a pipe or bong , not much goes through them when they get caked. I cleaned mine with brake cleaner.
Old 11-04-09, 07:44 AM   #9
SorrGwa
Trader Score: (0)
SorrGwa's Avatar
Send a message via ICQ to SorrGwa Send a message via MSN to SorrGwa
on the 2jz 3.0L, its located just behind the intake cam sprocket on the top of the engine. you will see a black plug into what looks like a device thats in the valve cover.
to replace, unplug the plug, remove the 10mm bolt that holds the ocv in place, then give it a good yank. should come out relatively easy. some oil my spill out a little. all in all, should take you no more than a couple minutes,
or a couple hours if ur drunk, blind, deaf, cant read and prefer to use your feet.
__________________
http://www3.telus.net/SorrGwa/Clublexus/clublexus_banner.jpg
99 GS300 - Starfire Pearl White
Injen | Greddy T-belt / Sprocket | B&M Trans Cooler | Tanabe Touring / Megan y-pipe | Tein SS / Brembo Slotted / Hawk / Goodridge SS / Daizen Sways / Bushings | MRR 20" GT1s / Falken 452s | JP 3piece Wing / Blick Roof / JDM Visors / Greddy Lip / Philips 6K HIDs / 01+ tails / 01+ grille / Custom Black housing | Custom White Curtains | SPC & Exact Camber | Pioneer Head / Focal / Hertz / JVC / JL |
SorrGwa is offline   Reply With Quote
Old 11-04-09, 10:03 AM   #10
speedaddic
Trader Score: (1)
speedaddic's Avatar
Clifton, I can't find the "pipe or bong" on my gs400's engine diagram. Do you have any diagrams of that?
__________________
Tags
2000, 300, code, control, filter, gs400, lexus, ocv, oil, p1349, problem, remove, sc430, sys, system, valve, vvt
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Go
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
Copyright © 2000-2008 Internet Brands, Inc. All Rights Reserved
Privacy Policy | Disclaimer | Terms of Use | JOBS
