This Forum is Sponsored By:
Go Back   Club Lexus Forums > Lexus Model Forums > GS Models > GS - Second Generation
Thread Tools Display Modes
Old 09-19-09, 03:40 PM   #1
BA_GS400
Trader Score: (0)
Default '99 rear hub nut torque spec
I've been searching for about an hour now and cannot find a torque spec for that 30mm nut that is dead center of the hub assembly.
eg. take off the wheel, and it's dead center there, you can get to it without removing the rotor, and there's a small metal cap with cotter-pin holding it all from backing out.
Mine came off without too much fuss.......felt like maybe 90-120 lb/ft, but I'd like to know the actual torque spec. to put it back on.
Does anyone have that?
TIA!
__________________
99 GS400 Alpine Silver
1/4 stats: 13.98 @ 97.6mph
BA_GS400 is offline   Reply With Quote
Old 09-19-09, 06:39 PM   #2
BA_GS400
Trader Score: (0)
Oh, by the way,...I think screwed up the bearing in an incident with a curb. I put on the spare full-sized rim and just replaced the rotor tonight and things are better, but ther'es still a bit of a whir, whir, whir sound back there. Low pitched too, not high-pitched like the backing plate or anything.
I read somewhere that instead of buying just the bearing that I could get the whole 'hub' thing pre-assembled. Does that sound true? Think Carson Toyota would have something like that or is that aftermarket vendor kind of thing?
__________________
Old 09-19-09, 07:14 PM   #3
AshburnM3
Trader Score: (0)
torque 200 lb/ft
AshburnM3 is offline   Reply With Quote
Old 09-19-09, 08:08 PM   #4
Baliztik
2001 Lexus GS
Trader Score: (5)
Baliztik's Avatar
nevermind....
__________________
Quote:
Originally Posted by Brandizzle View Post
one little trick i found out to be effective is i pour common sense all over my tires. then right as im about to do a burnout. i dont. then i remember that im in a lexus and not a truck.
Formerly "azntalldud"
Baliztik is online now   Reply With Quote
Old 10-02-09, 03:07 PM   #5
BA_GS400
Trader Score: (0)
Thanks Ashburn. that hooked me up.
A NEW QUESTION NOW:
I *thought* I had read that you could get the bearing and hub (?) assembly together, then a backyard mechanic like myself could just bolt it in place since I do not have an 80 ton press.
Anyone got any advice on that? I did call Carson Toyota but they said it was not available.
I'm at a loss as to where I would go to get a new bearing pressed in.
Either way, I'm going to need some torque specs on the hub assembly now I guess.
Anyone got those numbers?
__________________
Old 10-04-09, 07:58 PM   #6
BA_GS400
Trader Score: (0)
Anyone?
I got shafted by the local auto parts place. They said they were ordering the hub/bearing assembly, waited a week for it to come in, and it's only the Timken bearing, not an assembly at all.
If such a thing is available, I'm really interested in knowing where to get it.
Still could use the torque specs too if anyone has them.
__________________
Old 10-06-09, 04:36 PM   #7
BA_GS400
Trader Score: (0)
Please baby Please!
Tags
02, 300, 400h, assembly, bearing, gs, hub, is300, lexus, nut, rear, rx, rx300, spec, specs, tire, torque
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Go
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
Copyright © 2000-2008 Internet Brands, Inc. All Rights Reserved
Privacy Policy | Disclaimer | Terms of Use | JOBS
