help please
Old 09-03-09, 06:04 PM
kevin.tran
kevin.tran's Avatar
Default help please
I'm sitting in a parking lot waiting for the tow truck. I was sitting at a light it turned green I proceeded to move forward than 30 seconds later my car jus died on me cruised to a stop put it in Parked tried turning it back on it'll turn on and than will die. any help would be apperiated
Old 09-03-09, 06:21 PM
mD5
mD5's Avatar
is it a weak start? check the battery terminals? maybe alternator is bad and not charging the battery properly? need more information, whats it do when you try to start it. how long does it stay running?
Old 09-03-09, 06:25 PM
kevin.tran
kevin.tran's Avatar
it starts like normal but than dies right after...strong start but jus dies when its suppose to stay on. the first thing I did was check to battery everythings tight I could get lik a quick second rev that's it
Old 09-03-09, 07:06 PM
carbongs
carbongs's Avatar
alternator? that is what is sounds like to me
Old 09-04-09, 12:30 AM
GS4_Fiend
GS4_Fiend's Avatar
try disconnecting the MAF sensor and see if it starts.
Old 09-04-09, 12:37 AM
masagsxr
masagsxr's Avatar
Yeah.. sounds like the alternator... Car can't run just on battery alone unless its brand new.. Even with that, It wouldn't last long. Car has to run above 14v
Old 09-04-09, 07:44 AM
FrankT
FrankT's Avatar
Yes, the car can run on the battery alone.
The ECU needs at least 10 volts to run the fuel injection with a low amp draw.
14 volts is the output the alternator has when the battery falls below 12.7 volts.
Typical alternator output on a 12.7 battery is around 13.4 volts.
I would be looking at the MAF sensor or intake tube.
Good Luck
Old 09-06-09, 07:32 PM
kevin.tran
kevin.tran's Avatar
Thanks for the help guys. The intake tube came off? I don't know how but it was off. I didn't see it untill I walked over to Autozone got a can of starter fluid. About to see if the fuel pump was bad and saw the intake tubing hanging. Reconnected it and started her up and everything was fine. That still Pi$$ed me off though because I wasted 2 hours. Oh well better than spending X amount of money to find and fix her. Thanks for the help!
Old 09-06-09, 08:44 PM
ARISTOh
ARISTOh's Avatar
Good Same thing happend to my uncles 1GS came to find out his Engine ECU went bad and had to be replaced...cost alot more then a can of starter fluid..
gs300F
02-29-16 06:34 AM
topgun129
08-03-13 10:02 AM
melski415
08-11-11 08:27 PM
SOLEdier
SC- 1st Gen (1992-2000)
15
06-16-10 04:11 PM
hyn_stunna
Performance & Maintenance
11-05-07 11:07 PM
Quick Reply: help please
