Squeaky Steering Column
Old 11-29-05, 04:54 PM
  #61
gserep1
gserep1's Avatar
As far as not having the steering wheel move when the key is inserted or taken out, just move the steering wheel all the way up while the key is in, and after that the wheel will not move again with key movement.
I very rarely move my wheel from the far up position, so I get very little use on this mechanism. I also make sure to move the wheel back up manually before removing the key and there is no problem.
If my motor ever goes out, I assume I will have to change it.
Old 11-29-05, 05:46 PM
  #62
imjohnphan
imjohnphan's Avatar
i called the local lexus dealership and they told me that they could only replace the whole steering wheel column and total would cost around a grand
Old 12-02-05, 03:51 PM
  #63
PhantomZX
PhantomZX's Avatar
Anyone have instructions on how to remove the plastic cover for the steering column?
Old 12-12-05, 03:54 PM
  #64
roller400
roller400's Avatar
So did anyone figure out how to fix this problem. In the summer, the movement would squeak. Now that it is cold, the damn think is stuck in the down posibtion and didn't retract. Only telescopes. Of course, it went down one more time, so now I drive with the wheel in my crotch.
Old 02-16-06, 10:50 AM
  #65
t42gs3
t42gs3's Avatar
I fixed this in Dec. 2003. There is a write, do a search for my screen name. You'll see my diy write up. I believe the thread is "motorized steering wheel tilt"
Old 03-07-06, 08:18 PM
  #66
liquidsilver
liquidsilver's Avatar
I just got my car out this evening (its below freezing right now) started it up . Now the Telescope wheel works fine but the Tilt will not. It's actually stuck at the top position and I feels like I'm driving a freaking bus. Everytime I hit the button, it makes a single click sound but it does not move at all. Hopefully it'll work in the spring when its warmer.....if not I'll take it into the dealer.
obakemono
SC- 1st Gen (1992-2000)
10-10-18 12:24 AM
ayonnebay
11-17-12 08:26 PM
bmauser
07-30-10 07:08 PM
daintyboy
11-21-07 01:43 PM
markjenn
04-19-01 04:47 PM
Quick Reply: Squeaky Steering Column
