Checking oil level for 2GS
Old 08-26-09, 06:08 PM
ivnnln
ivnnln's Avatar
Default Checking oil level for 2GS
Hello guys, I am just curious after changing the enigne oil. Do you guys check during the engine turn off, or while the engine is running and in D mode? Also, how many qt. did you normally put on yours GS? I check the forum for any previous post for checking the engine oil level, but with no luck. I put on around 7qts. When I check the oil level while the engine is running, it's right at the full level mark on the dipstick. If I check while the engine is off, the oil level is way pass the full mark on the oil dipstick. I looked up in the manual, it saids that 5.5qt with oil filter, but it's too low when I checked it an engine was running. So which is one is the correct way? Any comments are welcome. Thanks guys.
Old 08-26-09, 06:45 PM
phillygs3
phillygs3's Avatar
Old 08-26-09, 07:00 PM
Jason T
Jason T's Avatar
Check engine oil 5 minutes after running
How to check engine oil level
Have a look here for online work shop manuel
http://bahamutcars.free.fr/workshop/...nts/index.html
Repair Manual / LUBRICATION / INSPECTION
Old 08-26-09, 09:09 PM
5t341th
5t341th's Avatar
i change it, start the car, turn off car, check
when i changed mine, i put 6 qts
Old 08-26-09, 09:55 PM
GS4_Fiend
GS4_Fiend's Avatar
Listen.. If it's a V8. It takes about 5.5 quartz w/ the filter. After drain and refill. Start the car up for a few seconds. Turn it off and check. Don't overfill, it will cause oil burn, which will run down to the cats and would cause them to suffer and running hotter.
Old 08-27-09, 02:36 PM
ivnnln
ivnnln's Avatar
Default Thanks you guys
I rechecked mine afterward, and I drained it about a qt. off the oil's pan. I now have 6qts in the car. Thanks so much guys. You guys have been wonderful advisors.
Old 08-27-09, 02:49 PM
raytseng
raytseng's Avatar
Start the car for more then a few seconds. Get everything to operating temperature as the manual says.
The filter and all the channels fills up in a few sec so checking the volume is accurate after that point. But the real purpose of the full temperature startup is for you to look under the car for a puddle of oil indicating you have a problem...
Old 08-27-09, 03:19 PM
GS300ToM
GS300ToM's Avatar
Originally Posted by phillygs3
x100000000000000000000000
Old 08-27-09, 06:58 PM
McKrevice
McKrevice's Avatar
LOL, I sure hope this is a joke.
LOLOOLOLOLOLOLOOLOLOL
Old 08-27-09, 09:24 PM
alexulan
alexulan's Avatar
ivnnln man I realy hope you didn't put the car in drive then walked to the front to check the oil
That sounds pretty dangerous man.
as for the amount yes 5.5 is shy my 2000 v8 gs400 takes exactly 6QT.
Old 08-28-09, 05:44 AM
Rock-a-Lex
Rock-a-Lex's Avatar
No, problem man...this probably enlightened others as well to be honest. As far as I know the ONLY fluid (level) you check while the car is running is your transmission fluid; it should be on point and bright pink/red.
Old 08-28-09, 08:27 AM
fordsvtmfl
fordsvtmfl's Avatar
i think you should leave this up to the oil change places...lol
Old 09-03-09, 10:27 AM
ivnnln
ivnnln's Avatar
Smile
I did not check the oil level with the shift gear in D and that can be very unsafe. I normally have the Oil Stop did my oil changed, but I decide to do it myself since it was not that diff. to do. Thanks everyone. You're guys have been a great helped.
iamhippo
06-18-18 05:52 AM
tea
08-18-15 10:22 PM
Br7oom
05-21-15 06:20 AM
lx470man
IS F (2008-2014)
06-11-09 08:57 PM
4evDev
Maintenance
13
08-16-06 02:34 PM
Quick Reply: Checking oil level for 2GS
