Hard starting, need help
Old 07-06-09, 08:24 PM
Och
Och's Avatar
Default Hard starting, need help
In the recent couple of weeks my 01 GS430 developed a problem starting up. I need to crank it for a long time before it finally fires up, and sometimes it will only fire up on the second try. After it starts, it seems to lag a before reaching around 2500 RPMs, and then takes off like a bat.
Replaced spark plugs over the weekend with no result. Everything in the car is maintained well, new fuel filter, timing belt/water pump were recently replaced,
throttle body cleaned, new o2 sensors, new MAF, etc.
What can it be? There are no codes whatsoever. Could it be the fuel pump? And if its the fuel pump, would it be likely for the car to start hard but run well at higher RPM range?
Old 07-06-09, 08:28 PM
Och
Och's Avatar
Oh yeah, another thing... lately it seems my fuel mileage took a huge crap, the car noticeably wastes more fuel than ever before.
Old 07-07-09, 06:02 AM
DASHOCKER
DASHOCKER's Avatar
Long cranking is a sign of a bad fuel pump.. Was your old fuel pump bad? They seldom need replacing unless you encounter the symptoms you mentioned in your original post. I am still on my original fuel pump with 106k on the clock.
Old 07-07-09, 07:30 AM
McKrevice
McKrevice's Avatar
I'd say pump like mentioned. When you turn the key, pressure builds up, but the pump appears to be losing pressure causing it to crank and crank. Not sure if our cars have a fuel pressure regulator, but if so, that might also be the issue.
Old 07-08-09, 12:49 AM
Och
Och's Avatar
Hey guys, before I drop money down on a new pump, is there a way to test it to know for sure? Like testing the fuel pressure?
Old 07-08-09, 01:30 AM
denut-L
denut-L's Avatar
My brother had the same problem but he has a camry and we put in some fuel injector cleaner and problem solved.
No hesitation at low rpm's and start up's
GL
Old 07-08-09, 12:21 PM
GS4_Fiend
GS4_Fiend's Avatar
You would need a fuel pressure gauge. The pump is probably weak. Also make sure there are no vacuum leaks.
Old 07-09-09, 03:59 PM
jhill20
jhill20's Avatar
First of all Bad fuel pumps are not common with toyota/lexus. That being said, it does "sound" like a fuel delivery issue.
You will need a fuel pressure gauge, with most likely a certain fitting to access the fuel line, not remembering off the top of my head if it has an access port or not.
Old 07-09-09, 04:09 PM
GS4_Fiend
GS4_Fiend's Avatar
It's lacking in spark or fuel... Or even BOTH. (CKP)
Old 07-16-09, 05:31 PM
knotsofast
knotsofast's Avatar
Default Try some fuel system cleaner
I had similar symptoms, so I decided to run through a tank with fuel system cleaner. It's gotten better but not completely gone. I am now on the second tank w/cleaner; hope it clears up.
Old 07-16-09, 06:14 PM
skperformance
skperformance's Avatar
At first it sounds like a pump but if it goes away at higher RPM then it is not since that is the reverse of the problem it causes since it starves the engine as it increase in demand .
I would lean to a vac leak or maf issue first.
Throttle body cleaning and seafoam are good cheap starts before replacing anything to get a base line.
Old 07-19-09, 08:41 PM
Och
Och's Avatar
Well, I'll be taking the car to a professional hopefully tomorrow. I tried new maf, and bought two new coils, which I kept swapping in until I got though all eight. No improvement so far.
I think its probably fuel pump/pressure regulator/fuel dampener issue, or maybe even injectors issue. I'll update on the progress.
P.S.
This is the first real issue this car has had in its 115k miles.
Old 07-20-09, 09:54 PM
Och
Och's Avatar
So now I pretty much know for sure the fuel pressure is too low. Theres a fuel hose going up to the engine, and compared to the same hose in my friends GS430, it feels 50% less pressurised, both when the car is on or off. I wonder now if thats the fuel pump or leaky injectors.
Old 07-24-09, 10:50 AM
knotsofast
knotsofast's Avatar
Well w/mine, I found the previous owner replaced the vac hose on the PCV valve with plain rubber. Over time, line was collapsing from the suction. I swapped out with vac line; starting is back to normal.
Old 07-24-09, 11:21 AM
BLAZE
BLAZE's Avatar
Check the battery, when was the last time you replaced it ? These cars run pretty f,cked up with a dying battery.
Quick Reply: Hard starting, need help
