Install LOC at sub or before amp (which wires?)
I've done enough searching...I give up!!
I'm installing the line output converter--I've read to splice into the sub wires before they get to the factory amp (if so, which wires), and I've read it's OK to use the amplified signal at the sub but there's only like 30-80hz there.
Which is correct?
Which is correct?
There are four wires coming out of LOC. 2 of them + (positive) and 2 of the - (negative). Do I just combine two positive/negative from LOC together and then conacct them to positive/negative subwoofer wires?
splice and solder the LOCs wires just before the sub terminals. one + and one - to each side. Then, once you have everything connected, run it at low volume to make sure you have the wires correct going into the subs. If you put a - where the + should be, the subs will suck in first, then push out, thus RUINING your bass response.
Big Mack
This is not a hard and fast rule, however. Just because the subs are out of phase does not mean it will ruin the response. Subs are simply moving air. Provided you have a single sub, it's doubtful you'd even notice it's out of phase (especially in a trunk). If you have 2 subs, so long as they are wired the same way with regard to polarity, it will not automatically ruin the response. It is good practice to have it hooked up correctly, but in the event the LOC is hooked up improperly and feeding the signal to the amp in reverse polarity, there is an easy fix - wire the outputs in reverse polarity as well.
Big Mack
Big Mack
Wiring the outputs in reverse polarity with regard to the LOC is the exact same thing as changing the polarity of the sub input wires, just on the other side.
Big Mack
Which is correct?
Which is correct?
Can someone please make this clear to me, want to install this weekend, thanks
save yourself the trouble of burning something up, I know your one of those DIY guys most of us are, but when it comes to electrical, and its still complicated, evan after 14 diff members help, Bro just take it to a local shop!
BTW what part of texas you from?
