Clean Your MAF
Old 04-20-09, 10:46 AM
Billh2
Billh2's Avatar
Default Clean Your MAF
If your car has around 100K on the clock and your MAF has never been cleaned, believe me, it needs to be cleaned. This is especially true if you use a K&N air cleaner. It's a simple job, one connector and two screws, spray it with CRC MAF cleaner and put it back.
Cleaning it cured an annoying part throttle lean flat spot.
Old 04-20-09, 11:03 AM
MPLexus301
MPLexus301's Avatar
Cleaning your MAF sensor and throttle body has a pretty noticeable impact on idling as well as gas mileage. I just did mine recently.
Old 04-20-09, 11:05 AM
Infamous 1
Infamous 1's Avatar
Damn it, you just reminded me about what i was suppose to do when i installed my intake this weekend!
Old 04-20-09, 11:32 AM
neurocity
Neu`roc´i`ty
neurocity's Avatar
Good info...I just creeped over 73k so maybe I will do mine.
Old 04-20-09, 01:26 PM
Billh2
Billh2's Avatar
I just drove the route where the flat spots were the most pronounced. (A pretty good incline entering a freeway) What a difference cleaning the MAF made! This is going to be a regular maintenance thing for me in the future. I suspect that the fuel economy will also be improved, but I won't make that claim now.
Old 04-20-09, 01:31 PM
sakataj
sakataj's Avatar
repost....
https://www.clublexus.com/forums/per...revisited.html
but yeah it does help. i did mine....getting bout 1-2 more mpg extra
Old 04-20-09, 04:27 PM
5t341th
5t341th's Avatar
i did mine and noticed nothing. my car has 108k miiles
Old 04-20-09, 04:36 PM
GS4_Fiend
GS4_Fiend's Avatar
Usually you should change your air filter also when you clean your MAF. Or apparently, yours wasn't dirty enough to be cleaned.
Old 04-20-09, 09:39 PM
skperformance
skperformance's Avatar
Cleaning it is only a quick fix , as the ecu naturally cleans the sensor itself by heating up the element to break of debris.
After a certain time it needs to be replaced .
Old 04-20-09, 10:29 PM
Billh2
Billh2's Avatar
So, it should just be a matter of time before it gunks itself up again. At least now I know what to look for.
Old 04-20-09, 10:37 PM
skperformance
The only time it usually needs a manual cleaning is if you are using a K&N filter and over oil it causing the maf to get coated and throw a code.
Old 04-20-09, 10:51 PM
ek9max
ek9max's Avatar
I just cleaned mine and got an extra 50 miles per tank.
Didnt' even do the throtle body.
90k miles on mine.
Old 04-21-09, 08:30 AM
UDel
UDel's Avatar
I cleaned my TB last year but decided not to try cleaning the MAF after reading all the horror stories of the car going beserk and the MAF needing to be replaced after a simple cleaning/spray. Maybe in a couple years around the 100K mark I will risk cleaning it but I did not want to risk having to spend several hundred dollars on a MAF replacement after a simple cleaning just for a little better fuel economy or slightly smoother idle. The TB cleaning seemed to smooth out the throttle very slightly and made the engine a little smoother.
Old 04-21-09, 08:36 AM
Och
Och's Avatar
You shoundn't clean your maf at all, unless its contaminated by K&N type filter. I hate these filters, and I hope that K&N gets sued out of business in the very near future for making crook products that cause problems for unsuspecting victims. Nowhere in their marketing do they warn about potential MAF problems.
Now, the good news is that it is safe to clean hotwire MAFs such as the ones that come with our GS. Also, our MAFs are relatively inexpensive - a brand new one runs for less than $150.00
However it is not the same case for older models that use Karman Vortech AFM's. You cant clean them, and a replacement costs well over a grand.
Old 04-21-09, 08:50 AM
DumpedGS
DumpedGS's Avatar
wait, what? which cars use this type of sensor? this is the first MAF car i have ever owned so this is really new to me....i was just about to clean mine tonight after reading this thread...and now im really concerned. i have a 98 gs400.
Quick Reply: Clean Your MAF
