Where to hook up my LED Side Mirror Blinkers...
Old 04-14-09, 03:19 PM
TYPEII
TYPEII's Avatar
Default Where to hook up my LED Side Mirror Blinkers...
Nigel LED Puddle/Blinkers—Got the puddle lights to work, just need to find the wiring to hook up them blinkers, I don't want to run them to the headlight wires in the engine bay...Any options like fuse box or somewhere else...Picts or diagram will help.
Thanks
Old 04-14-09, 04:15 PM
Spyder78
Spyder78's Avatar
You can hook them up to the turn signal stalk in the steering wheel but then they wouldn't blink when you had the hazards on. The easiest way is to run it to the front and be done with it.
Old 04-14-09, 07:01 PM
wowitztai
wowitztai's Avatar
tru
Old 04-14-09, 07:08 PM
istundra
istundra's Avatar
Check the wires behind the cluster. Should have a good line there.
Old 04-14-09, 08:22 PM
speedaddic
speedaddic's Avatar
word...what he said. Pics are a must
Old 04-15-09, 01:51 AM
PHML
Master Thread Closer!!
PHML's Avatar
I just ran wires to my turn signals...and spliced the wires for connection.
Old 04-15-09, 09:44 AM
istundra
istundra's Avatar
It's a pain to run the wires through the firewall...
Old 04-15-09, 12:35 PM
speedaddic
speedaddic's Avatar
no its not...cut a small slit in the rubber boot..BAM...youre done
Old 04-15-09, 12:37 PM
PHML
PHML's Avatar
I ran mines to the rear tail lights to avoid any heat issues with the wire insulation.
Old 04-15-09, 01:03 PM
TYPEII
TYPEII's Avatar
Great Idea, gonna do it as soon as it stops snowing here...WTH, it's suppose to be Spring.
Old 04-15-09, 02:00 PM
AsGs300
AsGs300's Avatar
post pic of while your doing it if you coud, help us newbies out too for the future
Old 04-16-09, 08:17 AM
TYPEII
TYPEII's Avatar
Will do!
Old 04-16-09, 10:12 PM
skperformance
skperformance's Avatar
Why not wire it to the flasher relay under the dash drivers side.
Get the schematic for the 2 output wires and be done. no need to run the wire all over the car .
Old 04-17-09, 01:57 AM
REV-01
REV-01's Avatar
believe it or not i took only 5 minutes to find the 2 wires on the kick panel. i just look at the harness to rear and probe the wires even found them on the first crack.
so no need run all the way to the front or back.
Old 04-17-09, 02:01 AM
PHML
PHML's Avatar
This is the correct way to do it so you save on wires.
Unfortunately when I did this mod like 4 yrs ago...I didn't have a probe.
Quick Reply: Where to hook up my LED Side Mirror Blinkers...
