climate control servo
Old 04-07-09, 05:55 AM
DubbleURX
DubbleURX's Avatar
Default *UPDATE*climate control servo
Ok so ive searched and searched and cant find anything on anyone having to replace there drivers side climate control servo. All i can find is info on people changing the passenger side. Has anyone had to change theres out? If so, will I have to pull the dash (please say no)? Any insight or direction will be greatly appreciated.
Old 04-07-09, 12:33 PM
sakataj
sakataj's Avatar
i haven't done mine yet but im under the understanding that yes u have to pull the dash...its right above the climate control assy to the right of the gauge cluster. use same methods as when doing passenger side but make sure u order the correct servo. this wont be fun, i promise
Old 04-07-09, 03:46 PM
DubbleURX
DubbleURX's Avatar
sakataj i figured you would be the first to respond, thanks for the bad news haha jk. how do you know which servo to order? I already ordered it and have it in hand. I ordered : Product #:87106-30351, Lexus OEM Damper Servo Sub-Assy. PLEASE tell me this is the right one.
DubbleURX
DubbleURX's Avatar
btw my drivers side is blowing hot air when the ac is on, if that helps any
Old 04-08-09, 11:56 AM
sakataj
sakataj's Avatar
its brian....and yeah i seem to be the heating/air guy on here. i do manage a heating and air supply warehouse so it is my forte and im actually knowledgeable on this....its just not a ideal spot for that servo. i have heard some people not completely removing dash just dropping steering wheel and doing it but i dunno.
when you start the car up....do u hear a a servo clicking and whirring?
yeah that servo is correct. would u mind snapping a pic of it for me? i will attach the part # and the pic to my DIY
Old 04-08-09, 06:33 PM
DubbleURX
DubbleURX's Avatar
brian, it does seem that you are GS AC go to guy. For a while it was buzzing when I started the car up, but over about 2 months it stopped. Im assuming that the servo went completely dead when it stopped. Me and a partner are gonna try to do this pretty soon. Hes a car audio guy and seems to know how to take every panel out of a car, so were gonna TRY to do this without completely pulling the dash. I will keep you updated and will try and log some of with pics. I dont think i will have enough time to do a complete DIY like you did on the passenger side. But heres the pic of the servo to add to your DIY:
Wish me luck!
Old 04-09-09, 09:36 AM
sakataj
sakataj's Avatar
Wish me luck!
yeah mine did that when i bought it....i initially greased it but that worked temporarily at best! have fun and good luck....oh come on though...if u doing this REALLY rare servo (most people wont tackle this one) isnt it worth taking the time to do the DIY with all pics and a nice compete write up not just partial pics and a partial write up?
thanks for pic and part # i updated my DIY with info from yours so now u DEF need to do a DIY on the drivers side servo
Old 04-11-09, 08:20 PM
DubbleURX
DubbleURX's Avatar
Default DIY on drivers side AC servo
To anyone who may unfortunately encounter the same problem that I had with the drivers side AC blowing hot air. When I encountered this problem I searched a little and could only find threads with people having the exact opposite problem: passenger heat blowing cold air. So if there is no other DIY on this; here you go:
First thing you need to do is remove the black panel closest to the brake/gas pedals. Remove the two screws and a little tug and it pulls right off. After that pull a ninja move and find a way to be able to look up into the steering column; I pushed my seat back as far as it could go and snaked my way up there and this is what you will see:
After you get to this point its 3 screws that hold the servo in so just pop it out and put the new one in. The part from Sewell with CL discount: Product #:87106-30351, Lexus OEM Damper Servo Sub-Assy, Quantity:1, Price:$126.78, Item Total:$126.78
Old 04-13-09, 09:05 AM
sakataj
sakataj's Avatar
man thats crazy....i was under the conclusion that this was UNDER the dash like up by the gauge cluster
Old 08-05-09, 05:53 PM
sakataj
sakataj's Avatar
op....need to ask you something. i sent you a pm btw. do u have a pic of the drivers servo more viewed out i guess to say?
Old 08-13-09, 06:48 AM
edhmom
edhmom's Avatar
I have a question. My problem is opposite. In the summer, the AC works great on both sides. In the winter, there is no heat going to the driver's side. Would this be a driver's side servo motor problem?
Old 08-13-09, 12:55 PM
sakataj
sakataj's Avatar
maybe/probably..its def a temp servo though. is one making some noise or just not working correct?
Old 08-13-09, 07:23 PM
edhmom
edhmom's Avatar
The one on the passenger side is making sort of clicking sounds. I don't hear anything on the driver's side. Would the passenger side servo affect the driver's side heat?
Old 08-15-09, 07:50 AM
philags300
philags300's Avatar
my car just started doing almost the same thing expect no cold air for the passenger which servo would that be?
Old 08-17-09, 12:50 PM
sakataj
sakataj's Avatar
temp servo....
upscope76 (06-26-20)
Quick Reply: climate control servo
