20x9.5 +39 non staggerred???
Old 03-29-09, 07:56 PM
ek9max
ek9max's Avatar
Default 20x9.5 +39 non staggerred???
I got a buddy that is selling some wheels to me pretty cheap. He got them for an LS but never put them on.
Anyways, they are lexion 201 20"
20x9.5 +39 are the specs for all 4 wheels.
How would they fit with a 2001 gs430 on df210/kyb gr2's?
Thanks in advance!
Old 03-29-09, 07:57 PM
jcat_350
jcat_350's Avatar
depends on tire sizes. You'd need a stretch in the front, probably 225 or so, in the rear i'd go 255 with a shave and/or minor pull.
Old 03-29-09, 08:46 PM
[ant]
[ant]'s Avatar
i guess it depends what you want it to look like. i reckon you could go 235 fronts as i have 9" +27 with 235/35 no probs and yours are 6mm less aggressive overall (taking into account your extra width but higher offset). you may have to roll a bit & remove the black plastic trim.
rear yeah 255 would be okay, bit less stretch than up front. may not even have to remove trim or roll.
Old 03-29-09, 09:08 PM
mex lex
mex lex's Avatar
245s will fit on the fronts, no roll or trim required. You won't need anything on the rears done either.
Old 03-29-09, 11:05 PM
ek9max
ek9max's Avatar
Anybody got pics of a setupi similar to this???
Old 03-29-09, 11:10 PM
ek9max
ek9max's Avatar
obviously with a 235/35/20 tire, my speedo will be way off right?
Old 03-30-09, 12:09 AM
sleeper408
sleeper408's Avatar
I don't think you would need to go with 255/35 in the rear. A 275/30 should work fine with that wheel width and offset in the back. I would run a 235 or 225 up front to be safe. You may run into some problems with a 245/35 if you hit a hard dip while turning.
The only other thing is that the wheels may look a bit funny because your front wheels will be aggressive but the rears will not.
Old 03-30-09, 12:22 AM
CK6Speed
Super Moderator
CK6Speed's Avatar
Depends on what you consider way off. It should be about 2.5MPH slower at 60.
Old 03-30-09, 05:41 AM
[ant]
[ant]'s Avatar
9.5 +39 wont be aggressive up front.. itll just be 'okay' at high ride height and not much camber.
rear will be sunk haha
Old 03-30-09, 09:05 AM
ek9max
ek9max's Avatar
how sunk are we talking about?
Old 03-30-09, 09:21 AM
LEXUS_KID
LEXUS_KID's Avatar
How much does he want for these
Old 03-30-09, 12:12 PM
jcat_350
jcat_350's Avatar
sunk to the point where you should run a 15mm spacer, bringing your effective offset to +24.
i think some of you guys are missing the fact that he's on DFs. The rear will definitely require a shave if you're running 20x9.5 +39 with a 15mm spacer dropped almost an inch and a half. The front will be fine, but to make it look right i'd suggest a 10mm spacer.
Old 03-30-09, 05:22 PM
sleeper408
sleeper408's Avatar
ek9max: You should definitely consider running spacers in the rear for these set of wheels to look "right" on your car.
Old 03-30-09, 09:18 PM
istundra
istundra's Avatar
I would try to go for 245/35/20.. might be a mild stretch since 245's fit best on 9" wheel.
Stick with the same tire size front and rear. Use spacers for the rear to push it out.. and rotate your tires!!!
Old 03-30-09, 09:20 PM
ek9max
ek9max's Avatar
With spacers over 5mm i'll ned new studs right?
Quick Reply: 20x9.5 +39 non staggerred???
