Check engine light, code PO171, GS 400 need help
Old 03-28-09, 09:31 AM
ping702
ping702's Avatar
Default Check engine light, code PO171, GS 400 need help
My 99 GS 400 is having a problem with O2 sensors. The check engine light comes on with PO171 Bank 1 code. I changed out all the O2 sensors, But the check engine light won't go off and it's still showing the same code, PO171 bank 1. I also failed the smoke check. Any advise and suggestion is Greatly appreciate. Thank you.
Old 03-28-09, 09:33 AM
UncleRay
UncleRay's Avatar
Have you reset your ECU by removing the negative terminal from the battery for a half hour? May help
Old 03-28-09, 06:29 PM
BCP43002
BCP43002's Avatar
Some of the other things are:
Air induction system
Injector blockage
Mass air flow meter
Engine coolant temp. sensor
Fuel pressure
Gas leakage on exhaust system
Open short in heated oxygen sensor (bank 1, 2 sensor 1)
circuit
Heated oxygen sensor (bank 1, 2 sensor 1)
ECM
Did you reset your CEL or give it time to cycle itself off?
Old 03-28-09, 07:09 PM
GS4_Fiend
GS4_Fiend's Avatar
Make sure the oxygen sensor is from Denso. And reset the light.
Crossxup11
06-19-19 07:04 AM
Seadaddy
01-22-17 07:27 PM
Bud
RX - 1st Gen (1999-2003)
12-12-07 11:46 AM
t0ekn3e
02-13-07 12:42 PM
ColtSwitch
11-15-06 01:17 PM
Quick Reply: Check engine light, code PO171, GS 400 need help
