Rough Idle
Old 03-12-09, 08:44 AM
rew1977
rew1977's Avatar
Question Rough Idle
I have a 99 GS with 150,000. Just recently it began to idle roughly and would stall here and there, but it runs smooth on the highway. Check Engine Light came on and VSC/VSC OFF lite. Codes were reading a bad O2 sensor and multilple misfires and variable valve timing. I got the O2 sensor replaced and found that my valve gasket cover was leaking oil into the spark plug area. So went ahead and replaced valve cover, new spark plugs and wires, throttle body cleaning and fuel injector cleaning. The car has more power and runs smooth on the highway But it still seems to Idle pretty rough when coming to stops. Any Ideas what this could be???
Old 03-12-09, 08:52 AM
Spyder78
Spyder78's Avatar
Throttle body needs to be cleaned. Maf sensor cleaned or replaced. Try those and see what happens.
Old 03-12-09, 09:07 AM
rew1977
rew1977's Avatar
Throttle body was cleaned. Maf was not cleaned or replaced though.
Old 03-12-09, 10:11 AM
FrankT
FrankT's Avatar
Did you replace both valve cover gaskets?
Check for air leaks and or vacuum lines that are disconnected.
You may want to clean the MAF sensor with the proper cleaner.
is this a GS300 or400?
good luck...
Old 03-12-09, 11:02 AM
SorrGwa
SorrGwa's Avatar
any more codes?
my rough idle,,CEL code and VSC lights and abs all related to a bad vvti sensor.
Old 03-12-09, 11:26 AM
rew1977
rew1977's Avatar
Its a GS 300.
Old 03-12-09, 12:29 PM
macd7919
macd7919's Avatar
Have you checked your oil levels? If you were leaking oil and the oil got low you could trigger a vvti code as it is driven by oil pressure.
Old 03-12-09, 08:03 PM
GS4_Fiend
GS4_Fiend's Avatar
Sounds like engine mounts.
Parson
07-05-17 08:49 PM
foreste1
05-24-17 06:40 PM
okinawa2jz
05-15-14 12:05 AM
Dennzo
11-28-12 04:45 PM
sandygarf
02-12-10 08:08 PM
Quick Reply: Rough Idle
