Signal Flasher relay?
Old 03-10-09, 11:20 AM
excluesive
excluesive's Avatar
Originally Posted by sam430
BTW.
You just need one relay...the one I linked is for 4 led ... that relay is for LED blinker for front and back. If you do just two, you might have to get a different relay.
Just pull the old one and replace with the new one. It has a clip on the fuse box...and the relay itself has clips on both sides.
I mean, worse comes to worse, I can run out and buy LED signal bulbs for the front. Not a big deal
Old 03-10-09, 11:25 AM
sam430
sam430's Avatar
yep. the front is 7440.
Old 03-10-09, 12:34 PM
Rick James
Rick James's Avatar
The relay is located under the driver side kick panel..it's a pain in the but to get to. It's a little above all the fuses and it's clipped on to the fuse housing.
looks something like this:
you will lose confirmation blinker when you lock the doors with your remote however youwiill still get the beep.
Thanks Sam430, this is the EXACT info I was looking for. I will be ordering the relay sometime this week as well.
Old 03-10-09, 12:39 PM
RMMGS4
Northern California Regional Officer
RMMGS4's Avatar
Originally Posted by excluesive
You have my answer in your first sentence - it works and it is cleaner, also, no heat is created. I don't like using resistors in fear of melting stuff. I almost feel like in certain cases they are a bandaid.
I assumed your reason and you verified. I think the availability of these relays has not been that widely known since many continue to recommend resistors.
So if I can get an exact link to something that would work, that would be awesome!
edit: just saw the one sam430 posted, i will be ordering tonight
Please let us know how this relay works out for you. I haven't seen your sequential signals so that would be nice to see as well.
Old 03-10-09, 01:56 PM
Vic Nyce
Vic Nyce's Avatar
...and I tried, and ended up blowing up my brake failure sensor module. That was a nice 250 dollar present to myself...
LOL funny shet!
what does sequential leds mean? is that like the mustang GTs?
Old 03-10-09, 02:54 PM
excluesive
excluesive's Avatar
Originally Posted by Vic Nyce
LOL funny shet!
Funny shhet, yes after the fact. But the 4 hours that the shop spent locating the problem (on top of what I tried) was not cool. I am lucky I have good friends that help me out or this could have cost a bunch more than that. Plus, no lamp out icons on the dash now.
except better
RMMGS4 - I have a video at home but it is 170mb's. I will try to convert it to a smaller format and post it up.
Chris
Old 03-10-09, 02:58 PM
excluesive
excluesive's Avatar
I think that is the problem too, that too many people look for the "common" fix.
Old 03-10-09, 03:00 PM
RMMGS4
RMMGS4's Avatar
except better
Chris
Sounds good
Though resolution will suck, you could post a YouTube
Old 03-10-09, 03:23 PM
excluesive
excluesive's Avatar
Sounds good
PM'ed ya man
Old 03-10-09, 05:39 PM
GS300Rich
GS300Rich's Avatar
On the sylvania bulb chart it says the turn signal is an 1156 bulb. Can anyone clarify?
http://www.sylvania.com/ConsumerProd...RG-Results.htm
EDIT: I just checked myself and it is a 7440, sorry I doubted you sam430
Old 03-10-09, 08:31 PM
excluesive
excluesive's Avatar
Sounds good
here ya go man!
http://www.youtube.com/watch?v=yi2TPNv7qcc
Old 03-10-09, 09:49 PM
skperformance
skperformance's Avatar
I have the same relay on my LS and it works great for having LED's on all 4 corners. I have had it for about a year and cost $6 on ebay from HK .
Never checked for alarm blinking as i have an aftermarket one anyway.
Old 03-11-09, 07:40 AM
excluesive
excluesive's Avatar
thanks SK, I ordered the part today, I'll let you gusy know the outcome
Old 03-19-09, 08:54 PM
GS300Rich
GS300Rich's Avatar
anyone replaced this relay? If so can you take a pic of it in position or take a pic of the relay it replaces? I got to the fuse panel and there are 2 relay side by side, I think it is the one that is towards the front of the car, but it is about half the size of the relay pictured above. Can someone help me locate this relay?
Old 03-19-09, 09:24 PM
sam430
sam430's Avatar
the grey one
Quick Reply: Signal Flasher relay?
