Maintenance Question (Timing Belt, Water Pump, etc).
Old 02-11-09, 07:22 PM
g5cubed
g5cubed's Avatar
Default Maintenance Question (Timing Belt, Water Pump, etc).
Hey Guys,
I am currently at 112,500 Miles with my 2000 GS400, and I am looking to replace my timing belt, as well as the water pump. The 90k service has not yet been done.
I have selected the following parts to order and have my mechanic to install. I was wondering if there is anything else you would recommend when replacing when doing the timing belt job.
1. Part Number: 1354050030 Camshaft & timing - Tensioner Tensioner, ls400, sc400 - 4.0l 1990 - 1994
$53.50 $0.00 $44.40
2. Part Number: 9091602586 List Price Core Price Your Price
Maintenance & lubrication - Engine service - Belts & pulleys - Serpentine belt Serpentine belt, ls400 1990 - 1994
$50.37 $0.00 $41.81
3. Part Number: 90311A0001 Front crank seal Front crank seal, lx470 - 4.7l 1998 - 2007
$9.55 $0.00 $7.93
4. Part Number: 162710F010 Gasket Gasket, lx470 1998 - 2007
$5.57 $0.00 $4.62
5. Part Number: 1356809070 Timing belt Timing belt, gs400 - 4.0l, 4.3l 1998 - 2000
$52.33 $0.00 $43.43
6. Part Number: 161005927583 Water pump, gs400 1998 - 2000
$143.07 $0.00 $118.75
Thanks.
Old 02-13-09, 10:43 PM
bursond
bursond's Avatar
You should flush ALL your fluids(Brake, Transmission, Differential, Radiator, PS) if you haven't already, Spark pulgs, Carbon Cleaning, and Drive belt as well. I did all mine at 90k at the DS, cost me too$$$. Good luck.
Old 02-14-09, 12:27 AM
kit cat
kit cat's Avatar
Originally Posted by g5cubed
Hey Guys,
$53.50 $0.00 $44.40
$50.37 $0.00 $41.81
$9.55 $0.00 $7.93
$5.57 $0.00 $4.62
$52.33 $0.00 $43.43
Thanks.
why are you selecting parts of different engine? I know some parts can be shared but just curious.
Old 02-14-09, 06:54 PM
g5cubed
g5cubed's Avatar
Thanks will definitely do that.
Not sure what you mean. I thought these were the parts closest to the timing belt, and since I'm doing that, it would be easier for me to replace them now (as service was not done) than later on.
Old 02-14-09, 08:46 PM
Big Mack
Big Mack's Avatar
Exclamation
Maybe he means the fact that you've got LX470, LS400, SC400, and GS400 listed. See below:
1. Part Number: 1354050030 Camshaft & timing - Tensioner , ls400, sc400 - 4.0l 1990 - 1994
$53.50 $0.00 $44.40
Maintenance & lubrication - Engine service - Belts & pulleys - Serpentine belt, ls400 1990 - 1994
$50.37 $0.00 $41.81
3. Part Number: 90311A0001 Front crank seal, lx470 - 4.7l 1998 - 2007
$9.55 $0.00 $7.93
4. Part Number: 162710F010 Gasket, lx470 1998 - 2007
$5.57 $0.00 $4.62
5. Part Number: 1356809070 Timing belt, gs400 - 4.0l, 4.3l 1998 - 2000
$52.33 $0.00 $43.43
Thanks.
Now do you see what he's talking about? It seems highly unlikely that the seal and timing belt are the same for a GS400 and and LX470, given one is a 4L and the other a 4.7L.
Might want to double check your numbers/parts.
Big Mack
Old 02-15-09, 12:37 AM
g5cubed
g5cubed's Avatar
Big Mack
Oh, I see.
I got the part numbers off a past-thread (https://www.clublexus.com/forums/gs-...w-to-soon.html). I checked the part numbers with Carson and they were all compatible with the GS400. Also, it wouldn't be too much of a stretch for the GX and GS to have the same seals, and the GS and LS to have the same timing belts, given the same engine platform.
Old 02-15-09, 01:35 PM
bursond
bursond's Avatar
Exclamation
Hey Guys,
$53.50 $0.00 $44.40
$50.37 $0.00 $41.81
$9.55 $0.00 $7.93
$5.57 $0.00 $4.62
$52.33 $0.00 $43.43
Thanks.
Go to: http://www.sewellpartsonline.com/category2.asp?cat=ENG for part codes, pics, and prices.
Good Luck!
Old 02-15-09, 01:56 PM
GS_OREO
GS_OREO's Avatar
Don't forget your cam seals.
Old 02-15-09, 08:59 PM
FrankT
FrankT's Avatar
Yea, lets talk about cam seals for the 400...
WHO has done these?
Old 02-16-09, 03:20 PM
magnetik
magnetik's Avatar
fwiw, if it's not much to rebuild your starter (if it's still factory).. I would do that too. Parts are like $10. I made the mistake of forgetting about it when I did my 120k service. It now only starts up after a few tries. I wish I would have just thought about it before, while everything was apart and saved on labor.
Old 02-16-09, 03:32 PM
g5cubed
g5cubed's Avatar
Thanks, I'll look into this.
Old 02-16-09, 09:25 PM
kit cat
kit cat's Avatar
WHO has done these?
raises hand
Old 02-16-09, 09:26 PM
kit cat
kit cat's Avatar
timing belt doesn't involve taking off the intake manifold assy.
Old 02-16-09, 10:57 PM
FrankT
FrankT's Avatar
Default thread highjack
This is for those who are contemplating replacing cam seals for the 400.
raises hand
TWO quick questions;
IS IT POSSIBLE to remove the camshaft timing tube from the intake cam leaving the cam in place by just remove the front bearing cap and unbolting the drive gear? It looks like it may be possible but I don't know...
If the intake camshaft must be pulled must the exhaust camshaft be pulled as well?
Here is how it it shown in the FSM
Old 02-16-09, 11:06 PM
kit cat
kit cat's Avatar
dude, I wish I could help you out but with the VVTi, I decided to have the dealership do it . It was actually the first time I took the GS to the dealership.
Quick Reply: Maintenance Question (Timing Belt, Water Pump, etc).
