gs radio wire harness
i am looking for Wire Harness for my Lexus GS 300 . ? i need wire harness just plug in orginial manufacture radio. and convert to my new radio, i just bough a jensen double din , but i don't want to rewire my car, i just need wire harness that can do convert to aftermarket radio. without lossing the factory amp. i been looking around, couldn't find one, i see that ppl make their own ,but im no audio guy to be messign around with things of that nature
i been reading write up on how to make the harness but it not clear if any 1 done this recently can they help me out here im dying to install this doubledin
You're not going to be able to use the Factory Amp ..... if you do a search you'll find that it doesn't accept the industry standard line-out levels. Right now I am powering the four door speakers directly from my D3 headunit ... the eD sub is running bridged mono from a Soundstream amp.
I bought two harnesses 1) to make a patch harness to power the headunit and a seperate 1987+ to plug into the speakers at the factory amp connection.
Here's how I wired it up:
To hardwire to the factory harness (2001 Pioneer Harness)
Blue/Yellow stripe (battery (always HOT))
Gray ACC (switched)
White/ Black Stripe (Ground)
Light Green (Illumination)
To patch the speakers use a 1987+ up Toyota Harness (Metra 70-1761)
DaveC
Gray ACC (switched)
DaveC
The way I pulled it off was to extend a Toyota harness to the factory amp and rearranging the pins within the harness. The factory amp is no longer used and I have no sub at this time. Also the power is connected from the rear of the stereo using another Toyota harness for just one wire. Ground is bolted to the metal chassis.
This is the best of what I can remember from a year and a half ago.
yeah thank that sound about what i read b4..
bossgs4: pointed out a good diy and i figured out throughj this..thnaks bossgs4 for the link
https://www.clublexus.com/forums/gs-s...k-40-pics.html
redbarron
SC- 1st Gen (1992-2000)
06-18-11 08:23 AM
