Picture Request: 17inch gs400 wheels with 30mm spacers.
yo guys i wanna see what 30mm spacer looks like on the 17inch stock gs400 wheels cause i just order some 30mm spacers for the rear wheels let me know
how much smaller can i go i got 45 series on it..i was hoping running the 30mm and give me alot of camber in the rear. i saw the 25mm it was almost flush but it was off a bit.
I know for a fact you can run 15mm in the front and 25mm in the rear. Chrispy and many other members have done it.
Your main concern would be if you hit the inner lip in the rear. That should have been obvious by now. If you hit it, you will need to shave your fender. You probably wont find many pictures of stock 17's with a 30mm spacer. The member on the other thread said it fit no problem with his 16's. The difference between 25mm and 30mm is only 5mm.
I would make sure your suspension is stiff and wont rub or hit when you are driving over bumps in the road if you plan on using 30mm.
not exactly what you asked for, but for comparison purposes - 30mm front / 35mm rear spacers, oem 17's, lowered to max on tein cs v2 before i converted suspension to air.. rear fenders shaved, tabs in front rolled up;
front 30mm
rear 35mm
you can see from the pics that even with this much of a spacer, the oem 17s still arent flush with the fenders.. there's a guy in the 2gs classifieds selling 13mm front 25mm rear spacers advertising this will give "flush" fitment when used with oem 17s, now obviously you can tell from my pics that thats not going to be the case, but i didnt feel like crapping in his f/s post.. good luck with whatever you decide to go with..
front 30mm
rear 35mm
