Go Back   Club Lexus Forums > Lexus Model Forums > GS Models > GS - Second Generation
Sign in using an external account
Register Forgot Password?
DIY on changing servo motors
Thread Tools Search this Thread
Old 08-05-14, 08:41 AM   #376
aneidiaz
Trader Score: (0)
aneidiaz's Avatar
@AirplaneCockpit
Quote:
Originally Posted by RainyGS View Post
This looks like a pain, but mine is making some noise. Thank you so much for the write up and pics. Will make this job a little easier in the long run.
--- Once you get it and know what your dealing with its not hard at all bro. Plus we're all here to help each other. Anything your confused about, just ask man.
This ad is not displayed to registered members.
Register your free account today and become a member on Club Lexus!
aneidiaz is offline   Reply With Quote
Old 08-11-14, 04:08 PM   #377
JUSTAV6
Trader Score: (0)
My compressor turns on and off like crazy specially when the car is a bit hot during this hot vegas heat. Is my AC Copressor shot? Also for some reason my passenger side vents blow harder than my left ones. I have replaced the passenger side servo motors for some new ones, but I have not changed the driver side. What you guys think?
JUSTAV6 is offline   Reply With Quote
Old 08-13-14, 04:17 PM   #378
Jewcano
No Sir, I Don't Like It
Trader Score: (4)
Jewcano's Avatar
Send a message via ICQ to Jewcano Send a message via AIM to Jewcano Send a message via MSN to Jewcano Send a message via Yahoo to Jewcano Send a message via Skype™ to Jewcano
Is this the same issue here? I just got this problem a week or so ago. Does this on every startup as well:
Or is this a 'blend door motor' issue?
__________________
01 GS430 -Yeahhhh awesome ride!
Friendster!!!
Jewcano is offline   Reply With Quote
Old 08-15-14, 01:49 PM   #379
Jewcano
Trader Score: (4)
Jewcano's Avatar
It was the mode servo assembly. Took that sucker out. I don't feel like dropping $140 for a new assembly when I know the issue is the small motor. Anyone have a compatible motor model # that would work for it? Similar to the door servo motors?
__________________
Friendster!!!
Old 08-15-14, 03:29 PM   #380
baddis es
Trader Score: (3)
baddis es's Avatar
linkrim
Quote:
You can try this...
http://www.clublexus.com/forums/gs-s...rvomotors.html
http://www.clublexus.com/forums/gs-s...ete-guide.html
__________________
An Acura is a Honda, an Infiniti is a Nissan, but a Lexus is LEXUS !!!!!
-2015 Mazda CX-5 Sport -- family hauler
-2002 GS300 -- garage queen
-2002 Infiniti G20 5port -- daily driver
-1993 Acura Integra GS -- pastime
baddis es is offline   Reply With Quote
Old 08-15-14, 05:28 PM   #381
Jewcano
Trader Score: (4)
Jewcano's Avatar
Hey Baddis ES, we know it's the motor though, the rest of the parts are fine. Do you happen to know what the RPM is of the stock servo motor? I found this one on ebay:
Cut the shaft down, and pull the little worm gear spline off and transplant it, and dimension wise it will fit. I just would rather do the repair as such. My father took the motor out and wired it to his car battery. The motor itself did the buzzing noise like in the video I posted, and when I gently pushed the shaft downward, it went quiet and smooth. This one just needs a new motor. Potentiometer, Gears, etc are all good, the motor has too much play inside and needs to be replaced.
EDIT: Big edit lol. The mode assembly is fine I suppose. It's the one that was behind/under it that is the one at fault, that one is vibrating like mad. Gonna wait till my next day off to take it apart and see whats the issue.
EDIT 2.0: It was the worm-screw issue....... Knocked that little metal spindle up some, 0 worm screw play on it, put it back together and works good as new.
__________________
Friendster!!!
Old 08-26-14, 01:07 PM   #382
tek-rookie
Trader Score: (0)
Talking Air Mix Servo - RX300 - 3rd screw issue
I have a 2000 RX300 and the 3rd screw for the Air-Mix Servo is position behind two aluminum (heating/radiator) pipes. I tried a stubby screw driver but the angle isn't straight. Can you recommend another method? I don't think I need to loosen the bracket of the aluminum pipes.
http://ww2.justanswer.com/uploads/de...6_comp-003.jpg
or page 32-4 (two heater pipes in the way)
http://bio.souz-96.com/Lexus/RX300_R...nditioning.pdf
tek-rookie is offline   Reply With Quote
Old 08-28-14, 05:07 PM   #383
SharpGent
Trader Score: (0)
SharpGent's Avatar
TheSharpGentleman alexanderblake alexanderblake the_sharpgentleman
I have an 04 ES330 and I just pulled my mix/temp servo, adjusted and cleaned it, and put it back in.
BOOM. QUIET. No more strange animal sounds behind the glovebox.
HOOOORAAAAAAAAY!!
Thank you so much for all the amazing people on this forum for their trial and error, DIY, and best practices.
SharpGent is offline   Reply With Quote
Old 10-03-14, 08:18 PM   #384
Glenn F.
Trader Score: (0)
I' m also trying to replace the Air Mix Servo on my 2001 RX-300. I can get at remove the 2 screws on the bottom, but the aluminum heat/air pipes are touching each other and can get a screwdriver in between them to get at that "hidden" 3'rd screw.
There is a bracket at the top holding the 2 aluminum heat/air pipes down. Do I need to loosen or remove the bracket to make the aluminum pipes separate a little to allow me to get a screwdriver in there? If so, there is a phillips head screw on the side of the bracket or a hex bolt at the top of the bracket. Which one do I need to loosen or remove?
Also, what length/size phillips screwdriver do I need for that nasty 3'rd screw?
Glenn F. is offline   Reply With Quote
Old 10-06-14, 06:48 AM   #385
Blanco
Trader Score: (8)
Blanco's Avatar
I think I loosened the bracket for those pipes when I did mine. I used a short stubby screwdriver that had an adjustable right angle handle. It also ratcheted.
Another good option would be to use a 1/4" ratchet wrench with a socket that'll hold screwdriver bits. As far as size goes, it's either a philips #1 or #2.
Blanco is offline   Reply With Quote
Old 10-19-14, 04:23 PM   #386
baddis es
Trader Score: (3)
baddis es's Avatar
linkrim
Initial Issue: only blowing hot-air on both the driver and passenger side
replaced my cooling servo (passenger) with a new one and still no cold air. Arm is on the track correctly and am watching it adj through the temps...ensured enough freon was in the system, any ideas as to why no cold air?
EDIT: so after reading through the pages a bit more...maybe the driver's side needs replacing?
__________________
Old 10-20-14, 04:25 PM   #387
baddis es
Trader Score: (3)
baddis es's Avatar
linkrim
Anyone?????
__________________
Old 10-27-14, 03:41 AM   #388
dnelli
Trader Score: (0)
Quote:
Originally Posted by nsf0607 View Post
sakataj great writeup! Glad you took the time to share this with us. I know it will come in handy and I have included it to the DIY sticky.
Thanks again
Ditto dude! Thanks!
dnelli is offline   Reply With Quote
Old 10-27-14, 11:59 AM   #389
empera
Trader Score: (12)
anyone have the picture of the heater control valve servo?
empera is offline   Reply With Quote
Old 11-02-14, 01:20 PM   #390
Cacophony
Trader Score: (0)
Good writeup. I have a question about the airbag cable though. It says to unhook it.
How exactly do you do that? I have a 2001 RX300, and it looks like there's a little plastic panel that would unhook with metal tabs?
Thanks.
Click the image to open in full size.
Cacophony is offline   Reply With Quote
Similar Threads
Thread Thread Starter Forum Replies Last Post
DIY 2001+ LED Mirrors With Puddle Lights And Turn Signals sakataj GS - Second Generation 146 05-18-15 05:27 PM
DIY on changing center console bulbs/tranny gear indicator bulb sakataj GS - Second Generation 105 04-30-15 12:24 PM
DIY LED Audio Controls And Radio sakataj GS - Second Generation 82 05-31-14 07:58 PM
well guys look what i just had custom made sakataj GS - Second Generation 37 02-09-10 04:33 PM
just something new sakataj GS - Second Generation 38 09-25-09 01:08 PM
Tags
2004, 300, ac, clublexus, damper, dash, gs, lexus, lubing, motor, motors, recirculation, rx330, screw, servo, subassembly
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Join ClubLexus
Copyright © 2000-2015 Internet Brands, Inc. All Rights Reserved
Privacy Policy | Disclaimer | Terms of Use | JOBS
Get all contact info
