JeffTsai's DIY Videos: Servicing a 2JZ
Old 04-02-09, 05:03 AM
  #46
veljko98
veljko98's Avatar
jeff,
what about putting back all?
the position of camshaft pulleys and cranckshaft?
for getting start the engine?
And I know its not place to ask, but, can you help me with this situation:
I had some problems with vvti. find p1349 mistake. and when I removed time belt there was an oil on vvti pulley, even I have change the rubber behind it?
Do I have to get new vvti pulley? or it is becouse vvti valve???? ocv????
thank you!
Veljko
Old 04-21-10, 02:20 AM
  #47
pingu
pingu's Avatar
Did you ever finish the videos off?
Old 04-21-10, 04:07 AM
  #48
Rich23
Rich23's Avatar
Good job Jeff... I will send this to my boy. It will definately come in handy.
Old 09-27-10, 05:36 PM
  #49
masagsxr
masagsxr's Avatar
I know this is old Jeff but I never get tired watching all 5 parts of the video. What happen with Part 6 and so on? ..... I want to see how you remove the crank gear off and put the seals on etc...
Old 09-27-10, 05:40 PM
  #50
D-Boi
D-Boi's Avatar
awesome!!!!!!!!
Old 09-27-10, 08:18 PM
  #51
BlackoutGS
BlackoutGS's Avatar
These are Great Jeff, Thanks! Can't wait to see what our next Unit in Class will be about.
Old 09-27-10, 10:09 PM
  #52
pizdets17
pizdets17's Avatar
website doesnt work...
Old 09-27-10, 10:30 PM
  #53
JeffTsai
JeffTsai's Avatar
I stopped making the videos because there didn't seem to be much interest lol. I'll be posting up new ones in HD quality soon if I have time
Old 09-27-10, 10:36 PM
  #54
pizdets17
pizdets17's Avatar
cool, look forward to it
Old 09-27-10, 10:57 PM
  #55
masagsxr
masagsxr's Avatar
C'mon Jeff... Do you even check the view hits? Half of those are probably mine hehehehee
Old 09-04-11, 09:04 AM
  #56
mak89
mak89's Avatar
Bringing it back from the dead, there's still some interest from the CL community!
Old 09-04-11, 09:31 AM
  #57
LuxuryGS3
LuxuryGS3's Avatar
Co-signed.
I'd like to see more also.
Old 09-04-11, 08:21 PM
  #58
tinman
tinman's Avatar
These videos really helped me earlier this year. Thanks Jeff! You da man!
Old 02-10-12, 08:29 PM
  #59
bursond
bursond's Avatar
Default Good Job
Jeff, long time no see. I am still here and I still have my GS 300. I went to replace my plugs and found a lot of oil in the SP wells...It appears to be leaking from the VC's. I guess when I paid the stealership to replace my TB they did not replace the seals or the VC gaskets. Its a mess! I miss you guys now more than ever. I came back to watch your videos to remind me of some things. Do you still want to do my engine swap?
Old 02-22-12, 01:48 AM
  #60
imjohnphan
imjohnphan's Avatar
Hey Jeff, thanks for all the work and the great videos. I was wondering for the crankshaft seal is it the same with that tool? Just pull it out? And also how do you replace the OCV Valve? Is it easy to do?
And one last question, how do you set the timing back correctly when reassembling? I am assuming line up the dots on the cam pulleys and then set the crank to pulley line to the first mark and put belt back on?
Quick Reply: JeffTsai's DIY Videos: Servicing a 2JZ
