Tire Cupping - Inner Tire Wear HELP!!! PICS
Hi Everyone,
Thanks for all the responses.
I took it to a tire shop (Tire Pros), they have done pretty much all my alignments. They gave me a printout of my alignment and everything was in the green (i'll get it tomorrow and post the stats). They said when i took it back that it wasn't much adjustment needed. But i always seem to have this inner wear problem.
My car has 120K miles on it.
Do you think this is a Bushing problem then?
Thanks again for all the help!
lol yes it is a bushing problem, i got mine replaced with Daizen a couple weeks ago.
https://www.clublexus.com/forums/sus...-bushings.html
oh, look what i found.
http://www.l-tunedparts.com/product/?id=3014
interesting.
interesting.
Thanks again for all the posts.
From what I've read. the Daizen Bushing kit replaces the Upper and Lower Control arm bushings and the Caster arm bushings.
I also read that the Daizen LOWER arm bushing should NOT be installed. Should i replace the LOWER arm bushings with OEM versions then? https://www.clublexus.com/forums/sus...tial-help.html
I also read that i should repalce the Lower Ball Joints and Outer Tie Rod Ends.
I ordered:
1. Daizen Bushing Kit
2. Out Tie Rods
3. Lower Ball Joints
What should i do about the LOWER control Arm Bushings? I hear the Daizen ones cause a problem. Is there anyway to get OEM ones?
The lower control arm bushing i'm talking about is Circled in BLUE:
2. Out Tie Rods
smokyis350
08-07-12 08:53 AM
