HELP, shifter locked in park, abs light and brake light on!!!
help!!!!! i don't know what happened, but I parked my car and now it's locked in PARK and the abs light and brake light is on!!!!
i have a 2003 gs with no mods!
please help because i'm blocking like 6 cars and i don't know what to do!
i tried shifting into neutral to push the car from off, key in, key turned once, etc
the car turns on and everything i just can't do anything to move the shifter!
Right next to the shifter there is this 'override' thing you can pry out with a flat head. After that you can just use that flat head to press down on it and take it out of park. Hope it helps
please don't use a flat head. i believe your key is supposed to fit into that hole to the right of the shifter to unlock this! i think it has grooves made for your keys specifically (I'm sure someone will clarify this if I'm wrong and easily could be) but please don't go poking a flat head in there just yet in case it is made for the key! that way u dont damage ne of the grooves i think it has for your key.........ne1 wanna help me out and clarify or retort this?
i had the same problem where my lights were on and i could not shift it to any gear without overriding it. i figure out that the brake fuse went out and that what caused it. check your all your fuses. hope that helps good luck
jdmwongsta
10-25-08 12:20 AM
