cel code P0141 need help
Old Oct 1, 2008 | 07:16 PM
swat1727's Avatar
swat1727
Default cel code P0141 need help
i checked the code "P0141 Heated Oxygen Sensor Circuit - Bank 1 Sensor 2." what is that? i think it's the o2 sensor, does anyone know which sensor it is? and part #? thanks
Old Oct 1, 2008 | 07:33 PM
jcat_350's Avatar
jcat_350
in terms of the exhaust system being the stream, you have 2 banks in the stream.
engine being the top of the stream, first bank has 2 or 3 sensors i believe, the second one going toward the back of the vehicle is the one. Odds are, this sensor has gone bad. Just search around, i believe this problem has been covered before, you should be able to get a part number.
Old Oct 1, 2008 | 07:39 PM
swat1727's Avatar
swat1727
http://cgi.ebay.com/ebaymotors/ws/eB...m=250299755089
is this what i need?
LEXUS GS300 (2001) 3.0L L6 FRONT; LOWER; AT CYL 1-3 2JZGE
Old Oct 1, 2008 | 08:31 PM
jcat_350's Avatar
jcat_350
no, you would need part no. (denso) 234-4048
this is the part number for the sensor in the pre-cat bank that handles cylinders 4-6.
here is how your sensors go, as i clarified it for myself just now:
Bank 1: before the cat. Sensor 1 handles cyl.1-3, Sensor 2 handles cyl.4-6
Bank 2: after the cat. Sensor 1 again handles 1-3, Sensor 2 handles 4-6.
if youd like, oxygensensors.com has the denso part for 120, which is a very reasonable price:
http://oxygensensors.com/catalog.php...3835#Location1
Old Oct 1, 2008 | 08:51 PM
swat1727's Avatar
swat1727
i found this online, he is saying bank 1 sensor 2 is the one after cat but still cyl. 123. i am confused =/ what exactly is bank 1 sensor 2?
(1,2,3 precat) Bank 1 Sensor 1: 234-4048
(1,2,3 postcat) Bank 1 Sensor 2: 234-4626
(4,5,6 precat) Bank 2 Sensor 1: 234-4630
(4,5,6 postcat) Bank 2 Sensor 2: 234-4603
https://www.clublexus.com/forums/sho...ighlight=p0141
Old Oct 1, 2008 | 10:33 PM
jcat_350's Avatar
jcat_350
no, you're right, that's my mistake. I'm thinking banks in terms of upstream and downstream, it's actually just as you diagrammed it, in terms of cylinder banks.
bank 1 is cyl 1-3 and bank 2 is cyl 4-6, sensor 1 is precat, sensor 2 is post cat. 234-4626 is the one you need.
my bad damn sleep deprevation
Old Oct 2, 2008 | 12:05 AM
swat1727's Avatar
swat1727
haha cool thanks man for all your help!
Old Nov 1, 2008 | 03:41 PM
dustinnjit's Avatar
dustinnjit
Swat, were you able to clear out the code by order denso 4626? I got the exact same problem. Thx.
Old Nov 1, 2008 | 03:54 PM
DASHOCKER's Avatar
DASHOCKER
I had to replace an o2 sensor TODAY on my 2002 Rav4 which only has 35k on the clock
$250 bucks including labor. O2 sensors are not covered under the Toyota/Lexus 8/80k emissions warranty..The dealer also reflashed the ECU as a result of a TSB to re-calibrate the air fuel mixture which was too rich.
Old Nov 2, 2008 | 10:29 AM
mrploww's Avatar
mrploww
I too have the same CEL code. I replaced the correct sensor, disconnected battery and the CEL came back on within a few miles. I have been driving it for a couple weeks with the CEL on and for some odd reason it went off last night, then back on today with same code. I have an appointment with Toyota to try and figure it out.
Any suggestions for me to try on my own?
Thanks!
PandaGS300
Apr 6, 2015 01:40 PM
nicos1
Nov 5, 2007 05:47 PM
palaka
RX - 1st Gen (1999-2003)
Sep 3, 2007 06:58 PM
BklynJay
Performance
Nov 19, 2006 10:39 AM
Mac851
Maintenance
Sep 30, 2006 09:22 AM
