joint rubbing issue on front tire???
okie i have the ray 19s and currently there is a 225/40/19 on the front and 245/40/19 in the rear!
the front is a 33 oS the rear is a 30 OS and its a staggered set up by .5". 19x8 and 19x8.5.
I went to go look at some tires today and the guy at the shop told me if i run my rear 245/40 in the front it would hit the joint. And by the looks of it with the current 225/40 there looks like there is a 1-1.5" clearance between the joint and the sidewall/top of the tire. does anyone know what im talking about. i want to run a bigger tire in the front and im scared it will hit that joint with i go on bumps or just in general!!
any help would work thanks!!
1 Post
If he is talkin about the upper ball joint ......... I'm pretty sure the joint moves up and down with the wheel so there shouldnt be any issues
i have 245s on my fronts; my fronts are 8.5s though. yes that joint moves up/down.
my front only rubs when i make left turns on dips; all others are cool. my siggy shows how low i am.
you should clear easily w/those g35 wheels, all around.
also, are you sure those are the correct offsets?
seng278
04-03-18 12:11 AM
