GS300 Octane Question
Old 08-03-08, 01:42 AM
dkhuynh
dkhuynh's Avatar
Default GS300 Octane Question
Does the 2nd Gen Lexus GS300 REQUIRE or RECOMMEND Premium (91) Gas?
I don't own one so I can't look in the manual nor can I look at my gas cap.
I am sure the GS400 and GS430 require 91 octane,
but I am curious to know if the GS300 doesn't knock on 89 octane.
Thanks!
Old 08-03-08, 01:47 AM
AYEmike
AYEmike's Avatar
Thanks!
recommends 91 and higher
Old 08-03-08, 07:50 AM
lexusscturbo
lexusscturbo's Avatar
I've used good tier 89 and 87 when I've been broke for the past few weeks..No knocking yet..Just feels slower and I don't romp on it at all then; and just gently take off/slow down.
Old 08-03-08, 11:50 AM
lexusscturbo
Louie you do know you can run 91 without adverse effects correct?Even High compression factory OE engines can run on 91 without issues
Old 08-03-08, 12:03 PM
GS FONZy
GS FONZy's Avatar
Originally Posted by louiegs400
in my gs400, i dont put nothin but premium *93* gas in mine it even say's it on inside the gas tank
the car will not run right if you dont put the right gas in it
as far as g300 iam sure u can get a way with reg gas ?
Not true. You can run lower octane, but your engine will not reach peek performance. The ecu retards the timming, so you will not get any knocking.
I do only use premium because saving $4 a fill is not much etherway and it would be pointless to have horsepower adding perfomance parts and cheap out on gas. However my girl always uses 86 on her IS, which is the same engine as the GS300 and her car runs fine. She rather spend the extra $4 at Sturbucks that's her fuel
Old 08-03-08, 02:35 PM
Downfall75
Downfall75's Avatar
I've been using 89 octane ever since the gas spike. Yes, the car does respond slower, but I don't even need the performance around where I live.
Old 08-03-08, 02:59 PM
scottgs
scottgs's Avatar
I believe most all performance lexus cars require the 91 octane. The engine will detonate and run crappy. You might be able to get away with running med grade every other tank, as long as you can mix it with 93/prem.
Old 08-03-08, 05:40 PM
jcat_350
jcat_350's Avatar
ive been running 89 since ive had the car and it runs just fine....
Old 08-03-08, 07:32 PM
98GS430
98GS430's Avatar
I run 89 in my GS3, and throw in a tank of premium from time to time without an issue
Old 08-03-08, 10:29 PM
GS FONZy
GS FONZy's Avatar
its not big of a deal from 91 to 93 in gas price's its only few cent's more belive it or not
i never put 91 in my car always put 93 , and my car runs fine
i belive right now
prem 93 is $4.59 a gallon
and 91 is $ 4.20 or some thing like that its onyl few cents less why not just pay and get the best ?
on prem gas 93' to me it last longer idk if any 1 feels like that but to me last i dont really drive fast but like i feel that higher gas prem last longer then reg gas
Yeah, not all states sell 93
Old 08-04-08, 07:28 AM
JiBBeL
JiBBeL's Avatar
I feel bad for yall... 93 is about $3.85 in Missouri
Old 08-04-08, 07:38 AM
scottgs
scottgs's Avatar
Yeah its about the same here in TN.
You know 90% of the lexus I test drove and looked at stated premium fuel on the cap. So if you can run cheaper without issues, then I would do it. I am all for not buying top notch stuff all the time too. Of course I havent had this lexus long enough to know yet.
Old 08-04-08, 08:44 AM
lexusscturbo
i belive right now
Higher the octane the faster and more easily it combusts
Old 08-04-08, 11:12 AM
habeeb89
habeeb89's Avatar
I would personally stick with 91 +, it's not a big difference in $$ if you fill up with prem. and not reg. - max of $10
Old 08-05-08, 12:31 PM
raytseng
raytseng's Avatar
Uh, you got it backwards, but we understand what you mean.
Quick Reply: GS300 Octane Question
