A Proposed Solution To Gas Increase
Old 06-17-08, 07:11 PM
aristo2369
aristo2369's Avatar
Originally Posted by morris
What do you mean by -10 or -5? AF ration is normally given as 12:1 or 14:1.
10:1 is rich and 16:1 is lean
i dont know, the reation i believe has to do with air/fuel mix. -10% is lean and +6% is rich mix where you can smell the gas.
Old 06-17-08, 09:59 PM
morris
morris's Avatar
My guess is since we are talking about an APEX SAFC, they are talking about adjusting the correction factor by -10% or -5%.
Neither or which I would do unless i was able to monitor with a Wideband in real time.
Old 06-18-08, 05:32 AM
19psi
19psi's Avatar
Originally Posted by JeffTsai
The easy way is to get a Zeitronix wideband unit. It has a function built in called narrowband switching point. Basically, it will feed your stock ecu a slightly skewed O2 signal which will allow you to still use the stock ecu and run richer or leaner. What it does is tell the ecu is 14.7 when in reality the engine is running at 15.5 or so. This will allow you to save fuel during idle and cruise. Under full throttle, the engine reads off the MAF sensor and internal fuel map without referencing the O2 sensor. That is called open loop operation. So in theory using the Zeitronix wideband you can run a tick leaner at idle/cruise and still retain proper fuel at full throttle.
My friend is doing that on his IS300 and he's getting a notable fuel savings every tank.
so the zeitronix can be spliced into the stock harness? that's cool; it would definiitely work then as described.
Old 06-19-08, 08:22 PM
City Rider
City Rider's Avatar
Just wanted to add, I have a brand new Zeitronix ZT-2 Wideband with EGT and Map Sensor for sale...Pm me for details...
Codger07
Performance & Maintenance
08-31-17 07:30 PM
stevelifts
06-05-17 09:44 PM
tonybark
NX - 1st Gen (2015-2021)
43
01-19-16 09:36 PM
jb86
SC- 1st Gen (1992-2000)
05-20-06 08:53 PM
Quick Reply: A Proposed Solution To Gas Increase
