battery suddenly dead but works fine when jumped .....
the Gs is my daily driver and this has happened twice in 5weeks. its not a cold day or anything. matter of fact i drove it all day so alternator should have charged it properly.
here is what happed on both occasions:
i drive to where am going without a problem but when its time to leave (last time it happened, the time between turning car off and starting back to leave must have been like 10mins), the battery is suddenly very low. Not completely dead but very low to not start the car. the guages move and are dim but not enough juice to start car. i don't get any clicks which make me assume its not a starter problem. i jumpstart car and it starts right up.
here is the part i dont understand. after jumpstarting it, all becomes fine like it were before. i could shut it off in a minute or two and it starts up like battery was never dead or low.
its a oem Toyota battery but i have no idea how old it is. also there is no battery warning light coming up on dash.
what do u think?
dead battery? alternator? starter? what else?
thanks
olddog
what do u think?
thanks
olddog
There shold be a guide on the battery to check if its still good also check if you still have liquid in the battery....i think you can jsut add distilled water and it should work fine if its low.
Is anything grounding? I used to have the same problem then i found one ground wires were bad. Well good luck.
Also I dont know if there is any Kragen or Autozone there but they do free battery checks.
Same thing happened to me in two different LS' and in both instances it turned out to be the battery.... One was an original made by Panasonic and the other was an Interstate with about four years on it. With the latter, I was told it had a dead cell.
i have a dead beat maxima that i just bought a battery for. i guess i will just swap out the battery. but it amazes me how it shows no sign of dying. starts up fine and all.
better safe than sorry though...
don't wanna be caught with a dead battery on a hot date
I had a similar issue, it was the battery. Ran great when it would start, but needed to be jumped a little too often.You could also check the battery terminals, make sure both are clean and the connections are tight.
