lexus dealership and programming key
Old 01-06-14, 06:16 AM
  #46
driver1988
driver1988's Avatar
when i bought my car it came with what seems like 2 master keys. For some reason i lost one of them. The dealer is quoting 200 and 50/hour for labor for reprogramming. Is this worth the trouble? Should i just get a valet key?
Old 01-06-14, 03:48 PM
  #47
raytseng
raytseng's Avatar
If you lose another master key you are in big trouble, and it is up to you if you are responsible enough to not lose the remaining key.
The valet key isn't going to be much cheaper, but the price you got from the dealer seems high.
1) You can check your local locksmith to see if they have the capability to do this work, and if their price to do the work is cheaper than the dealer..
2) You can order a key from Sewell for example for cheaper. You can try programming it yourself, if you fail or can't get it, you can bring it to the dealer or a locksmith and hope they still charge you only $50 for the fee.
(Note, if you had some relationship or status with the dealer, like you came in earlier and spent $2000 on service, small potatoes labor stuff like this often gets waived)
Old 01-06-14, 07:28 PM
  #48
lexo98
lexo98's Avatar
Since you have one of the programmed keys just order another key and follow the programming procedures poster earlier in this thread. It works. I did it a few weeks ago
Old 01-06-14, 09:44 PM
  #49
ttaylor993
ttaylor993's Avatar
I agree with Lexo98, if you already have a master key, buy another key and follow the programming instructions to create another key. I too created another key by this method after crushing first master key, Order blank transponder key online and had it gut a local key shop. Then followed instructions presented in this thread PRECISELY to create the second key.
Old 01-07-14, 08:27 AM
  #50
driver1988
driver1988's Avatar
so just order a replacement key directly from Lexus dealership? went onto their website but didn't find anything. Is it a good idea to order from Ebay?
Old 01-07-14, 06:20 PM
  #51
aneidiaz
aneidiaz's Avatar
I think it be best to just take the car in by appointment. Have them make the key and make sure the key is working properly before giving the car back. Sometimes hassle free is the way. Worth saving for.
Old 01-07-14, 10:40 PM
  #52
shurian
shurian's Avatar
just look on kijiji or craigslist for a local car locksmith who does key programming as i did, i got a brand new key for 160$, this are mobile locksmith that does programming and cutting on the spot, try this site also
http://www.remotesremotes.com/
Old 01-08-14, 02:20 PM
  #53
driver1988
driver1988's Avatar
Thanks man!
Old 02-04-14, 02:27 PM
  #54
driver1988
driver1988's Avatar
Originally Posted by farkas
Key Programming 1. Insert an already programmed master key into the ignition. Do not turn.
2. Press and release the gas pedal 5 times.
3. Press and release the brake pedal 6 times.
4. Remove the key from the ignition.
5. Insert the new key you want to program into the ignition.
6. Press and release the gas pedal one time.
7. Wait 1 minute. The security light will be blinking for this one minute. When it stops blinking your key is programmed. To end programming step on brake one time.(Sometimes it takes LONGER than 1 minute,Wait it out)
NOTE: Look for your security light. This light will guide you during the programming procedure. The security light will go off at Step 1. It will remain off until Step 6. The security light will come on and start to blink after Step 6 until the key is programmed. If the security light comes on after Step 4 STOP the procedure and start over again.
I got all the way to step 7. The blinking light keep going on and on for more than 6-7 minutes. I heard it may take longer than 1 minute but 7 mins seems too long. No blinking from step 1-4.
Old 02-04-14, 02:53 PM
  #55
nyc80rick
nyc80rick's Avatar
I just did mine today because of this same post and it worked for me. just keep doing it a few times you will get it took me about 5 tries before I got the sequence down and it worked out for me. i ended up doing the key part first then programmed the remote in all took me 20min for the whole thing thats with me doing it a few times till i got it right.
Old 02-04-14, 04:45 PM
  #56
Tom57
Tom57's Avatar
Do the programming instructions above work for all 2001 - 2006 LS?
seanglenn
08-25-19 06:18 AM
lazycruzer
04-03-18 07:34 PM
ApolloRoad
08-25-16 03:27 PM
George Hsieh
10-18-04 10:02 PM
RelaxJoe
06-17-04 08:29 AM
Quick Reply: lexus dealership and programming key
