Auto-leveling headlights
Old 03-10-08, 09:13 AM
j_version_
j_version_'s Avatar
Default Auto-leveling headlights
is there a way to add the auto leveling feature to a gs or a kit you can buy?
Old 03-10-08, 09:29 AM
RI-Lex
RI-Lex's Avatar
Not sure if you add it, but only the GS that have auto leveling are with factory HID's
Old 03-10-08, 09:50 AM
VipDout
19x11.5 -51
VipDout's Avatar
Hmmm From my understanding when I got my JDM ones I needed something to plug into my suspension ?
Reason why I didn't follow through with it ..
Old 03-10-08, 10:17 AM
NBart
NBart's Avatar
Dumb thought, but couldn't you just purchase OEM HID highs and housing?
Old 03-10-08, 10:18 AM
JeffTsai
JeffTsai's Avatar
You gota hook up the level angle sensors into the suspension arms. For left front and left rear lower suspension arms. Then run the cables to the auto level control ECU at the front of the car under the headlights. Then run another cable over to the other side of the car for the second level motor. It's DO-able, but not really worth it in my opinion.
Old 03-10-08, 10:44 AM
GSteg
GSteg's Avatar
Autoleveling doesn't make that much of a difference anyways. Oncoming drivers do not really get blinded unless you're on a steeper hill. Even then, it still doesn't help
Old 03-10-08, 11:32 AM
GS3.0
GS3.0's Avatar
anyone know where to get the angle level sensors underneath the car? i've had the "HID level sensor" light flashing on my dash for the longest time and its annoying. also, my driver side HID is pointing upwards and blinding oncoming traffic. my mechanic says i need to replace one of the sensors underneath to make it work again.
Old 03-10-08, 11:40 AM
JeffTsai
JeffTsai's Avatar
I'm sure you can get it from the dealer. Or call up Luis at Carson Toyota to get a discount on parts.
Old 03-10-08, 12:16 PM
GS3.0
GS3.0's Avatar
they're pretty pricey...$300+ for one. lol
Maybe Aliga can get me one.
Old 03-10-08, 04:09 PM
milky
milky's Avatar
yeah, doesn't make that much of a diff.. just looks cool when you start it up.
Old 03-10-08, 04:38 PM
j_version_
j_version_'s Avatar
thats pretty much all i want it for lol
Old 03-10-08, 06:23 PM
GS3.0
GS3.0's Avatar
i can't properly level my drivers side HID bulb...it just points up blinding oncoming traffic...i can't manually adjust them...mechanic says i need one of those leveling sensors underneath the car...apparently one of them is cracked...
Old 03-10-08, 08:42 PM
gs4bkny
gs4bkny's Avatar
I am going to ask a dumb quesiton.......How does the auto leveling system works? And what is the purpose of the system?
Old 03-11-08, 04:15 AM
G430
G430's Avatar
Default Auto Leveling Problems...
Yeah i had mine my front sensors replaced last year.. it came out to be the rear that was damaged.. but i got the front ones covered from the extended warranty by accident... but yeah they got the levelers on the HID factory headlights so i believe its when your going up and down hills the leveler has sensors that automaticly adjusts the headlights housing to have better lightings..and yeah i am still tryna find a good deal for the sensors.. when i do ill hitt it up on the forums
GSsportD
18
02-16-17 07:37 PM
robbyk
02-16-15 12:59 PM
rohanstar
Build Threads
01-06-14 09:54 AM
RI-Lex
06-20-07 10:30 AM
chuckb
Lighting
11-02-05 02:23 AM
Quick Reply: Auto-leveling headlights
