clicking noise from rear end??
throughout time i thought this may be normal, i dont know if i had this sound when i got the car. well everytime i step on the pedal and give the car gas, i would hear a click from the rear end. i cant really tell if my car is losing power. or if my tranny is about to go out or differential. i can try and record the sound but i dont know if the apexi exhaust will over lap the sound.
I find it hard to believe that a clicking sounds would be a bad rear diff. Usually if they go bad they start to humm over about 35 mph. You need to put it on a rack and see if you can duplicate the sound for a mechanic to see what your problem really is!
Can you tell if it is on one side or both? I had that clicking too, and it was also the brake pads. I removed the pads and put a coat of RTV on the mating surfaces in the caliper and the noise disappeared.
When was the last time the differential gear oil was changed? I changed mine Friday night after 100,000 miles. The synthetic gear oil was still in very good shape. I use AMSOIL Extreme Pressure Synthetic 75W90 gear oil.
well it clicks when i hit the gas hard enough for the car to sit back and then the trans or diff would click. i cant tell. i know deffinitly its not the brakes. i didnt apply the brakes for the rear to make the sound
is the adjustment of the spring on the caliper that holds the pads in place??? does it just need brake grease???
SLVRGS
Suspension and Brakes
05-27-04 07:29 AM
