Now the turbo install...
The kit..
T61 T4 Turbocharger
Turbine: .84 AR, 3" v-band outlet.
Compressor: .70 AR, 4" inlet, 2.5" outlet.
40mm wastegate
27x7x3 Intercooler
TiAl-style 50mm BOV
2.5" piping
3" Downpipe
AEM UEGO wideband sensor
AEM F/IC piggyback
1.3MM HG
550cc SARD injectors (not installed until later)
Test dry-fit everything. It's almost like Lego's, and you can see the clearance in between everything so when it goes into your car, you'll know what you really need.
Drain your engine oil. You won't be reusing this oil so it's best to get new oil and a new filter while you're at it.
Here's the oil feed tap. Do not eliminate this sensor.
This..
Will go into where the sensor is.
The reason why I did it is because the wiring isn't long enough to reach all the way out there. If you put the first fitting onto the second fitting, it will be long enough to reach the sensor as long as it's at 9-12'o clock position.
Here's the complete picture.
Oil return plate
*Make your return hole at least 1/2". I highly recommend 5/8" though. Use a step drill-bit with a lot of multi-purpose grease (you want to lubricate and cool the hole so you don't grab onto the soft aluminum pan). Also picks up the shavings so not a big amount goes inside your upper pan (which can be catastrophic).
*Don't be lazy and do a drill AND THEN tap procedure for the 2 M8 holes. The bit that I used drills and taps and it seems to ****ed up the upper hole.
*Remove the thermostat unit to drill the upper hole. I doubt you have a drill that is small enough to fit in there AND also be powerful enough to drill on it. Some coolant will come out so be prepared.
*Use your favorite high temperature sealant as gasket. Be generous but make sure the sealant doesn't get into the oil pan!
*Flush out the metal shavings with your drain line, attached to the drain plate, and your used oil. Just don't forget to have a bucket to catch it. You WILL see shavings coming out, the more the merrier.
I highly recommend upgrading your feed and drain lines. -4AN for feed and -8AN for drain
(From Jegs.com)
Feed list (don't need NPT to -AN adapter)
555-100050 #4 STR HOSE END PUSH LOC
555-102200 #4 PUSH LOC HOSE 5' BLUE (or whatever length you need)
Drain list
555-100129 1/2"NPT TO #8 FLARE 45 degree bend
555-100107 3/8"NPT TO #8 FLARE
555-100052 #8 STR HOSE END PUSH LOC
555-102220 #8 PUSH LOC HOSE 5' BLUE (or whatever length you need)*
*People usually run -6AN for their fuel system, but if you decide you want to flow more, then you can go up to -8AN and buy like 20 ft. of this stuff.
Intercooler install:
If you have the 27x7 small and cute intercooler (that flows a lot of air), you're going to have to drill your own hole and customize mounting brackets. Home Depot is the answer.
Mount the brackets onto the intercooler, and then mount the entire assembly...
Onto this...
Complete picture
Turbo install:
This has been covered so many times, i'm just going to go over a few highlights.
-Make sure you rotate the turbo housing (by loosing the 4 bolts behind the turbine) to get to the 4th inner most nut that is impossible to get with a rachet. It's ok to not put that much torque onto the nut because the weight distribution makes the turbo want to lean out, not lean in.
-Careful not to get teflon tape into the oil system. Again, upgrading your drain lines to -AN fittings will solve a lot of these oil weeps and leak headaches (besides, it looks nice with the blue and the red and the light blue and the easiness of install/uninstall).
-If you have a better oil gasket, use it.
-Take off the compressor for easier installation and also drill a 21/64" hole and tap 1/8" NPT fitting onto the housing. You will need to run a positive pressure sensor to the fitting on the wastegate, otherwise your wastegate will never open.
-Make sure you put the giant o-ring on the compressor first, and then you put the housing over.
-Dry fit your downpipe to see if the v-band will fit over the turbine and the downpipe. If you're downpipe is way too thick, you can either cut the original flange and weld on a new one, or grind it down and use a gasket. I would recommend to cut the flange, grind it on the non-contact side, and then re-weld it. Use a gasket anyways.
-Use tabs of sealant around the flange for the TiAl 50mm o-ring. You'll see why.
I had the most problem with intercooler piping during my install, so here is mine:
I really like the TiAl style BOV. Besides, it sounds nice.
