Will this cordless impact gun remove crank bolt?
Good luck, getting the crank bolt off on the Supra was an insane task. I snapped a 1/2 Craftsman breaker bar and split 2 sockets open. Tried a 1000 ft/lb Ingersoll impact and it did nothing, also tried the wedge the bar and crank the car method to no avail. It sucked bad, in the end it was alot of heat to the bolt and 3/4" breaker and sockets that did it with a 4ft helper bar and 3 big guys working the bar. I'm going to have to do it all again when I put the lightened/dampened pully on their for the GS swap. I hope it goes alot smoother.
You can buy it at any autoparts/hardware store. Ever heard of Liquid Wrench? It's the same thing. You spray it on nuts/bolts that have sat up for a long time and let it soak in good. I used it to to get some of my exhaust manifold bolts off the Supra since they were abit rusty looking and went through all that heat cycling (l let it soak overnight spraying them a couple times) and they came off with ease.
http://www.pbblaster.com/store/morei...m?Product_ID=1
Jeff. lol i think you could use a few more feet on that breaker bar there sir it doesn't look long enough.
and yeah pb is the **** i used it when i did my header.worked like a champ!
Blk97SC300
Performance & Maintenance
17
03-29-07 07:00 AM
