gs400 transmission soldenoid problem!
Old 10-23-07, 06:39 PM
leinadmiih
leinadmiih's Avatar
Default gs400 transmission soldenoid problem!
got a problem...my car was shaking for a couple days now and then cel just came on, so i took it to a shop. mechanic said solenoid inside my transmission got messed up. Anyone ever had that problem? The mechanic said i have to basically rebuild my tranny or just get a different one. is there any cheaper way to fix this? the cel codes are p0715 and p0763.
Old 10-23-07, 11:36 PM
pimplux808
pimplux808's Avatar
i had my solenoid go out for my trans a couple years ago and i just bought the solenoid from lexus , it was around 260.00 ........i didnt put it in though ...the dealer did.....
Old 10-24-07, 06:35 AM
TRD911
TRD911's Avatar
if you can find out which one you should be able to change it. It looks like all you need to do is to remove the valve body and replace that solenoide
Old 10-24-07, 10:23 PM
TAMR_GUS98
TAMR_GUS98's Avatar
Originally Posted by pimplux808
i had my solenoid go out for my trans a couple years ago and i just bought the solenoid from lexus , it was around 260.00 and but that in ........i didnt put it in though ...the dealer did.....
I'm with these guys. If its just the solinoid you should be able to just replace the solinoid. Unless it happened to burn up the clutches in the tranny.
-Will
Old 10-25-07, 12:33 AM
leinadmiih
leinadmiih's Avatar
you guys know around how much it will cost to fix?
Old 10-25-07, 12:35 AM
pimplux808
pimplux808's Avatar
dam i only have the receipt of the part .......i forgot how much the labor was.....sorry
Old 09-27-08, 02:41 PM
SeattleGS400
SeattleGS400's Avatar
Default Here's a cross-reference link to P0763 code
Discusses the P0763 code, potential causes, and cost:
https://www.clublexus.com/forums/sho...21#post3872621
Labor: $240 (Lexus dealer)
Part: $224 (Carson Toyota)
Old 03-22-21, 12:15 PM
bluegs4
3rd Gear
bluegs4's Avatar
Had a similar problem with my GS400. The solenoid is easily replaced when the car is up on a hoist with the transmission pan removed. It's held by two screws and has a cable that is easily unplugged and moved to the new solenoid.
My transmission could not get into third gear with the old solenoid; it's fine with the new one. Easy repair if you have a friendly mechanic, no need for the dealer$$$. In my case, the diagnostic codes correctly identified the bad part and replacing it fixed the shifting problem. I've had other problems where the diagnostic codes were wrong, not this time.
I found a new Lexus solenoid at amayama.com. My only problem was clearly identifying the correct solenoid to replace. I found helpful documentation for this online.
Old 06-21-21, 04:47 PM
Ddk912
Ddk912's Avatar
I’m not having an issue (that I can tell), but the cel came in and it refers to the transmission solenoid. So basically, you’re say replace the solenoid and it shou be good. And this isn’t a bank breaker?
Old 11-08-22, 02:26 PM
bluegs4
3rd Gear
bluegs4's Avatar
I had a similar problem although did not experience shaking. It showed the 2-3 shift solenoid fault code in my GS400 and I drove the car for a while in limp mode without third gear. I found a solenoid online and replaced it when my mechanic had the car on the hoist with the pan off. Easy to replace, just one screw holding it in place. Transmission was fine after that.
Almuqarshi
01-26-19 05:45 AM
dookies92
RX - 1st Gen (1999-2003)
03-29-15 11:36 AM
Dx3
Performance & Maintenance
11-30-07 11:23 AM
gs400blue
11-17-07 03:24 PM
ryanSC400
03-26-07 10:22 PM
Quick Reply: gs400 transmission soldenoid problem!
