pulling fenders
Old 10-17-07, 02:44 AM
marshun
marshun's Avatar
Default pulling fenders
i searched and i dont think anyone on here really pulls fenders. but...i figure i'd ask anyway.
anyone pull their fenders to the max? im just wondering how far the fenders would come out on the GS. i ask cause i want to put the widest rims possible on there. i just want to be able to stop as quick as i can incase i need to do some sudden braking (ex: accident ahead)
Old 10-17-07, 06:07 AM
carlos
carlos's Avatar
here is one way to NOT pull your fenders: https://www.clublexus.com/forums/sho...d.php?t=310895
Old 10-17-07, 08:16 AM
carbongs
carbongs's Avatar
i've done a shaving of fenders diy but not a pulling fenders. when the gs3 goes into paint in a few years i will be pulling the fenders to the max i.e. cutting and pulling and adding fender moldings to go a little mini widebody.
Old 10-17-07, 08:25 AM
LEXUS_KID
LEXUS_KID's Avatar
That's something I wouldn't try my self. Take it to a shop that way there at fault if they mess up
Old 10-17-07, 03:26 PM
DriftGirl
DriftGirl's Avatar
They'll come out as far as a fender roller will stretch them....or a baseball bat.
Old 10-17-07, 04:07 PM
mole
mole's Avatar
pulling the fenders is likely to make your paint crack. I am planning on having my fenders pulled when I redo the car. I remember 1/2" being the result for a conservative pull.
Old 10-17-07, 04:54 PM
Kuroikaze
Kuroikaze's Avatar
You can get a way with a slight pull and heat gun. Anything drastic, you can expect body work.
Old 10-17-07, 09:32 PM
marshun
marshun's Avatar
i've done this before. gotta have the car out in the sun, heat gun, taped up, baseball bat. the paint doesnt crack. if it does its on the inner lip usually.
anywho, my 240 can fit 17x10 +12's all around after i did this. i know the rear came out at least 1.5 inches.
so no one knows how far the stock GS fenders would come out eh? i guess i'll just give it a go and then fit wheels on afterwards
emerald, why are you on so many damn sites? lol
Old 10-18-07, 12:04 AM
RMMGS4
Northern California Regional Officer
RMMGS4's Avatar
It' s not so much that no one knows, most people just seek other options.
You can put 20 x 11 rims with 305 size tires with no fender pull and no rubbing as long as you shave and select the right offset.
Do you want to go wider than that like 12" rims or more?
If not do a search to see how it's been done, without pulling.
If you just want the look or need some clearance, then go ahead and try pulling, but beyond a small amount, your only going to get so far without needing to repaint.
Old 10-18-07, 02:44 AM
PHML
Master Thread Closer!!
PHML's Avatar
We need a Fender Pulling 101 class w. pics.
Old 10-18-07, 06:30 AM
GSoup
GSoup's Avatar
Sleepless in Seattle.......
My rear fender is rolled but as several people have stated you need a heat gun and patience to do it without cracking the paint. Make sure you remove the plastic little parts behind the holes that the fenders plastic strip screws on to.
I believe one of the local guys is about to roll his fender this week or next, maybe I can get him to do a DIY.
Old 10-18-07, 12:12 PM
DriftGirl
DriftGirl's Avatar
Is this marshun from my old forum?!?!
when did u get a GS?
Im pretty much just here and VSC...but will be out n about now that my license is reinstated & probation over. LoL!!
About the fenders, mine are slightly pulled but I didnt go that aggressive on the GS. Metal will stretch paper thin if you stretch enough. The only problem I could see is making sure it 'looks good'. I thought about going with a slight 'wide body' but dont want to deal with the rear door area
good to 'see' u again
( D_G )
Old 10-18-07, 08:12 PM
V8_Aristo
Bippu
V8_Aristo's Avatar
https://www.clublexus.com/forums/sho...d.php?t=308386
Old 10-18-07, 09:30 PM
VipDout
19x11.5 -51
VipDout's Avatar
I was just about to post this
Old 10-19-07, 02:25 AM
marshun
marshun's Avatar
( D_G )
ha! crazy. got the GS a couple weeks ago. i still have the 240 (ls1 is done) and its still ugly on the outside. im painting a couple of cars so mine is on the back burner. still daily the civic though.
whats up with your 240's? pm me
Quick Reply: pulling fenders
