Door Lock Acutuators DIY ???
Old 10-23-12, 05:08 PM
  #871
69charger
69charger's Avatar
Your post is greatly appreciated, I need to replace 2 actuators w/closers if I can find them. Do you know of any classified having door latch/actuator w/ closers.
69charger
bryanjs@sbcglobal.net
Old 10-24-12, 09:35 PM
  #872
Jewcano
No Sir, I Don't Like It
Jewcano's Avatar
I just ordered 4 motors off ebay today. Less than $17 shipped. Gonna replace drivers and front passengers actuators as they've recently been giving me issues.
Old 10-28-12, 01:27 PM
  #873
minjarre
minjarre's Avatar
Just ordered 4 actuators, going to try it out
Old 10-29-12, 01:58 AM
  #874
SDGSPW
SDGSPW's Avatar
The easiest way to crack open the housing is by using a safety blade and a small hammer (like a model hammer). Line the blade up straight between the two halves of the housing and slightly tap until the blade goes in. Go all around the housing until you can separate the two halves. Any other way is too much of a pain to do.
Old 10-29-12, 03:08 PM
  #875
LexusK
LexusK's Avatar
Is $70 for a whole actuator a fair price? Seems a bit much considering people are buying the motors for just $17? Or am I mistaken and it was $17 for all 4?
Also, does it make a difference if I have a Viper 5901 installed with the remote start?
Old 10-29-12, 08:38 PM
  #876
Jewcano
Jewcano's Avatar
^ I bought all 4 motors for 17$ shipped.
Old 10-30-12, 06:40 AM
  #877
wbmx1981
wbmx1981's Avatar
I havent found anything quite that cheap, can you post the link? or do you know the sellers name?
Old 10-30-12, 12:08 PM
  #878
Jewcano
Jewcano's Avatar
Sent you a PM.
Old 10-30-12, 09:05 PM
  #879
SaiyanGS3
SaiyanGS3's Avatar
Sent you a PM.
PM me the info too. thanks.
Old 10-30-12, 11:09 PM
  #880
SDGSPW
SDGSPW's Avatar
A new actuator is around $275 - $300 each. The motor by itself is around $6 on Ebay.
Old 11-05-12, 02:13 PM
  #881
credle89
credle89's Avatar
Originally Posted by TRD911
I have edited this because there has been several questions about finding these motors on EBAY. The seller's name is tag16c and if you are looking for the motors a good place to start your search is "Mabuchi" the part number that we have been using FC 280PT-22125 If you go to Mabuchi website you can also see there are several other that will work but they want you buy quantities that are high, like 10K, there only like 30 cents a piece. I have attached a picture from tag16c 's auction I do not think he would mind. When I look for the auction I start by typing in Mabuchi then look for that picture below that I posted. I hope this helps. I know that this DIY takes a lot of different turns and it can be hard to follow. I have about 10 motors as spares... I hope this helps.
I did my drivers side door lock actuator today. I took several pics. Would anyone be interested in a small write up with several pics? I would hate to invest time in a topic no one would be interested in. Any comments. Do you guys wanna see my pics? I have never done a DIY but I did it myself and it was not toooooo bad. Feedback will help motivate me. Thanks, B
i have problem with my passenger back door lock sometime it locks and sometime it dont will this help this problem
Old 11-05-12, 06:00 PM
  #882
Dirtybrd
Dirtybrd's Avatar
I just replaced one in my LS with a aftermarket unit, $21 and done. Took maybe 30mins.
Old 11-07-12, 07:32 PM
  #883
2jS160
2jS160's Avatar
big ups to TRD911 for writing up this DIY
Thank you for the direct link
Old 11-12-12, 02:31 PM
  #884
bogie54
bogie54's Avatar
Default door lock actuator
I had no problems getting the motor in the actuator and getting the door lock to work with inside locks, but the key fob will not lock the doors with the newly installed motor. Any suggestions would be greatly appreciated. For now I have just disconnected the passenger side door to use the key fob , otherwise it will not lock any of the doors with the newly installed motor. Anybody encountered thhis problem and a quick fix.
Thanks , bogie54
Old 11-13-12, 12:19 PM
  #885
Jewcano
Jewcano's Avatar
I keep getting PM's....so here's the link:
http://www.ebay.com/itm/ws/eBayISAPI...m=121009099287
Quick Reply: Door Lock Acutuators DIY ???
