APEXI SAFC trouble....HELP!
Old 12-14-01, 07:29 PM
CSHFLW
CSHFLW's Avatar
Default APEXI SAFC trouble....HELP!
Wirring diagram for the SAFC is T-10a which shows the speed sensor four pins to the left on one of the plugs.....but there is no wire there.....empty pin....do I put a pin there? Also on another post someone said the throttle connect is wrong and is three pins to the left of the air flow pin.....Wheres the aif flow pin? nothing called that on the diagram...said it was a black/red wire, but the black with red stripe wire is the IG power wire on the far left of the ECU or far right on the diagram....whats up??? anyone experts know? also Apexis number on the box is wrong...any one know it?
Old 12-15-01, 12:12 AM
GlobeCLK
GlobeCLK's Avatar
Default Re: APEXI SAFC trouble....HELP!
Why do you need the speed signal? S-AFC shouldn't require you to tap the speed sensor, it's not on the wiring diagram.
Air flow pin is on the wiring diagram under Air Flow Signal. APEXi-usa.com has the diagram in case you feel yours is wrong.
Old 12-15-01, 06:02 PM
CSHFLW
CSHFLW's Avatar
Yea, on the T10a ECU pic I have...it says "speed"????
dunneo....I'm not at a computer right now with a cable conection and apexis site is too much for this POS to handle, maybe some one could please post the pic for me!
Old 12-16-01, 07:11 AM
LexusRules
LexusRules's Avatar
here is T10a Diagram
Old 12-16-01, 07:15 AM
LexusRules
LexusRules's Avatar
here is another thing
Old 12-16-01, 07:19 AM
LexusRules
LexusRules's Avatar
here is a 3rd
i dont wanna make it as bad as the Apex'i Website so i'll stop there if u need more just ask
Old 12-16-01, 07:21 AM
Richie
Richie's Avatar
Sasha, where did you get all those diagrams???
Old 12-16-01, 10:13 AM
LexusRules
LexusRules's Avatar
apex'i website
Old 12-16-01, 11:27 AM
CSHFLW
CSHFLW's Avatar
Thanks man....but the next question...which wire is the throttle wire???? it shows it on the ECU but not on the plug diagram????hmmmmm.....
Old 12-16-01, 12:25 PM
GlobeCLK
GlobeCLK's Avatar
Throttle wire is the one that says THROTTLE SIGNAL.
Do you know how to read the diagram? Not to be mean or anything but does it say THROTTLE SIGNAL right on the diagram? That's the one.
Maybe your diagram doesn't say all those things. What kinda diagram is that?
Old 12-16-01, 12:30 PM
CSHFLW
CSHFLW's Avatar
damn your rude....
WHERE DOES IT SAY THROTTLE WIRE OR THROTTLE ANYTHING ON THIS WIRING DIAGRAM???IT SHOWS IT ON THE ECU SIDE BUT WHAT WIRE ON THE AFC HARNESS?......
Old 12-16-01, 12:37 PM
GlobeCLK
GlobeCLK's Avatar
damn your rude....
Obviously you don't know.
The pic you posted is CONNECTION CHART. The T-10a is the WIRING DIAGRAM. Go look at that.
Don't yell. damn you're rude.
If you're asking for help you better listen instead of shouting back everything you don't understand.
And sasha, if you read the japanese on the 3rd pic you posted, it says WRONG WAY TO CONNECT THE GROUND WIRE.
Old 12-16-01, 03:55 PM
LexusRules
LexusRules's Avatar
i kno
just wanted to show what not to do sorry i didnt write that :-p
Old 12-16-01, 05:31 PM
CSHFLW
CSHFLW's Avatar
Ok and which wire on the AFC side is the Throttle wire??? Which color, etc? Why would they say hook the SAFC wire here(the throttle pin) and not tell you which wire out of the AFC is the one to hook to that point? Also it was posted before that the throttle placement is wrong.....any one coment on that?
Old 12-16-01, 06:45 PM
GlobeCLK
GlobeCLK's Avatar
The wiring diagram shows the throttle signal pin but on the connection chart it doesn't say you need that. How many wires are on the harness of the S-AFC? 6? RED GREEN BROWN BLACK YELLOW and WHITE?
Quick Reply: APEXI SAFC trouble....HELP!
