Radio Light
Old 06-14-07, 06:37 AM
DavesLexus
DavesLexus's Avatar
Default Radio Light
The light on my radio went out, the one the illuminates the radio station. Can that be replaced or do I need to buy a new radio.
Old 06-14-07, 09:47 AM
Primeraman
Primeraman's Avatar
I just bought my GS about two weeks ago and my radio light just went out as well. I'd to know if its an easy fix too....maybe its just a sign to replace the factory unit and begin modding.
Old 06-14-07, 12:32 PM
RI-Lex
RI-Lex's Avatar
my radio light is dimmed on one sided, plan on replacing the unit anyways
Old 10-01-08, 12:33 AM
ISFjimmy
ISFjimmy's Avatar
any input/ links guys?
Old 10-01-08, 01:02 AM
shvc1991
shvc1991's Avatar
Go aftermarket, but only if you really care about loudness and sound clarity.
If not, the LEDs behind the display are replaceable, but I've heard that you should really make sure you know what you're doing so that you don't fry anything. If you do change it, you can even change the color that the buttons and the display light up.
Here is a DIY right here.
https://www.clublexus.com/forums/sho...ht=radio+light
Old 10-01-08, 01:08 AM
shvc1991
shvc1991's Avatar
Okay, sorry about that. There is no actual DIY in that link, but I'm sure Rockero wouldn't mind if you PM'd him about it.
Old 10-01-08, 08:55 AM
ElitistK
ElitistK's Avatar
you can take the headunit apart. people sell replacement displays on ebay, and swapping out the display is a simple plug n play job once you have taken the headunit apart. if you're good with soldering, just take the old display out and replace the lightbulbs by de-solder and re-solder.
Old 10-01-08, 09:42 AM
CLT
Former Sponsor
CLT's Avatar
DavesLexus
If you want to keep the OEM radio, you can replace the all the bulbs in the radio. Just so you know the OEM bulb is 10mm wide X 12 high, you can find a couple of site that sell the replacement bulbs, you can even go LED if you want.
I'm MODing my OEM radio for the time just so oI can get rid of the GREEENN OEM color
Old 10-01-08, 11:29 AM
ISFjimmy
ISFjimmy's Avatar
bought the bulbs today at the dealer.
Old 10-01-08, 12:22 PM
Vadim540i
Vadim540i's Avatar
It's hecka easy, just replace bulb.
Echo419
11-13-12 12:00 PM
truenoboy
12-18-10 12:07 PM
Quick Reply: Radio Light
