how to add freon to a/c system
I just spent the last 45mins searching theforums but came up with nothing.
Can someone please tell/show me how to add freon to the a/c system. I think my a/c is not getting too cold. I don't know where or how to add freon so please be basic in your explanation.
also, what type should i buy and how many cans?
Pics, if possible, would help a lot too.
thanks alot
olddog
thanks alot
olddog
sounds like you have a gs3, but on my gs4 there is a low pressure (I think it was low pressure...) opening near the driver's side headlamp, to the rear of the radiator. its a good 12-14" down there so make sure that you get a long enough connector to the 134a can. I picked up one of those long cans with a replacable trigger thing with the meter (don't know what its called) that you can put on cans that cost around $10 each... just make sure that you use the meter to check to see if low 134a is really your problem.
i've done it several times, just make sure you turn on the engine and a/c before you put the gas in...
good luck
good luck
thanks man
how do i know what pressure is right.
i went to walmart and found a refrigerant called"duracool". is that good enough?
they were also selling this pipe connector thingy which connects to the can and i guess to the low pressure valve.
if i just hook this up this way and release the gas into the system, how do i know when its filled up or enough? i heard too much is not good.
i also hear of a leak stopper which you can put in the system. where do you get that from and how do you put that in also?
thanks
olddog
thanks
olddog
the connector i bought has a built in pressure meter in it.... i don't think that there is any way to measure the pressure without one.
jaja
jaja
also - i'm not sure about the leak stoppers... they usually have bad stuff in them (esp for tires... i would assume the stuff for a/c is no better....) maybe someone else has some info
I think you should get your ac system checked. Freon regenerates. When the system needs more it means there is a leak. If you fill it, it will just leak out again. That's okay if it only needs a reboost every year or so. But if it's frequent, it'll only lead to more problems. Get it checked out before the reboost.
sounds like I will do a DIY on this...be this weekend for you olddog
yes the gauge is low-tech but will show you when the system is full. and use the low pressure port sounds like you got it figured out. run the a/c on while charging watch your fingers while the engine is running. will have pictures if you want.
reggiek is correct as well
hey
reason i want to do this myself is cos the lowest quote i could get was $170. most said they don't top off the freon and have to do a full recharge.
don't have that kind of money to "give-off" for nothing.
the weekend is not far away and i can wait.
thanks alot
olddog
if u follow the A/c lines i believe on the gs300 2nd gen, mine was somewhere by the radiator behind the bumper, there is a clear glass thing for u to view the freon and a screw cap that has L printed on it for low end. If it has freon u might need to get it vacumed and recharged professionally, But if u wanna try for a can or two of r143a then have ur car running with ur a/c on full blast look at the meter and put in a can of freon to the Low end connector and u should see if the glass partion is filling up. I believe if ur freons on low it shuld take 2 cans of r134a on or systems
i changed my condenser last year so i don't know whether it needs a reboost. if you are talking about a recharge, the system works fine cos the compressor comes on and the temp gets cold. the a/c gets cold but not very cold as some others. even late at night when its cool it does not get very cold like other cars.
i would most definitely appreciate a DIY on this. And pictures would definitely be of great help.
thanks alot
olddog
thanks alot
olddog
i think i got all i need from what the guys offered. but what is better than a verbal training is a visual practice. i will wait till the weekend. so please go ahead and post some pics.
not just for me but also for the benefit of others who might need this.
i wish you could do it asap as i am one impatient bastard
BTW, will it be neccessary to check the pressure?
also, do you keep putting freon until it reaches the higher end?
thanks
olddog
thanks
olddog
Hey olddog, while you wait for pics to be posted, you might want to check for leaks which is fairly easy to do. Run your A/C and with a Gas Leak Detector check all the a/c connections, preferably starting at the condenser since you changed this last year. Then, if you can get a hold of a 134a Pressure gauge like this one http://buy1.snapon.com/catalog/item....re&dir=catalog you can check if your a/c system is working properly. I'm not sure what the correct pressures are for the GS. Hope this helps.
Note: If your A/C was not serviced properly, it will not cool as advertised, so if the DIY items don't work you might need to get it professionally serviced.
