Steering Wheel Shakes please help
Old 05-09-07, 08:49 PM
Jstunner56
Jstunner56's Avatar
Default Steering Wheel Shakes please help
Hello All, I am the owner of a 2000 GS 300 on 18" American Racing wheels. The problem is this when I drive above 35 mph the steering wheel start to shake slightly like a vibration at different times during my drive. When I go above 60 mph I also feel the vibration but alot more powerful one. Anytime I end up slowing down and applying the brake, the steering wheel will shake at 35mph to about 25 mph every time. Under 25 mph the vibration stops. I did some research and had my car taken to 3 shops for diagnostic to see the problem. One recommended an alignment which I did, 1 recommended a whole new suspension which i went ahead and had did as well. My bearing is fine, ball joints, tie rod fine and I also had my wheels rebalanced. The rotors do not need to be resurfaced according to one shop, but I have not seen any difference to why my cars steering shakes and more drastically at certain speeds. Can anyone offer any suggestions or insight into this problem.
Old 05-09-07, 08:52 PM
Bigbea
Bigbea's Avatar
rebalance your tires
Old 05-09-07, 10:01 PM
DSM2GS400
DSM2GS400's Avatar
hubcentric rings
Old 05-09-07, 10:25 PM
mole
mole's Avatar
Ok, before you do anything, please do a search on "vibrations" and "steering rack adjustment" and you will be answered...
Common problem that has been discussed. I used to have vibrations, and spent money with minimal results... now I am on high end 20" rims dropped with 0, count it for me 0! vibrations.
Old 06-27-07, 11:01 AM
Jstunner56
Jstunner56's Avatar
I followed everyone's advice and took my car in to be tested using the Hunter Road Force balancing machine. The shop said i had two bent rims and that could possibly be the culprit. I ended up putting both bent rims in the back of the bar and the good in the front hoping it would help eliminate the vibrations I feel in my steering wheel. Nothing has changed and I still have these vibrations. Any other suggestions?
Old 06-27-07, 11:21 AM
Chenzo26
Chenzo26's Avatar
If you have bent rims, I suggest not having them in the front OR the rear. How old are your tires? If you have not replaced your tires in a while you may in need of new ones. Sometimes old ones - and even not so old ones that are defective - will become out of round. You may also have a bubble in the tire itself. Again, if your rims are truly bent, take them off of the car, otherwise you may cause more damage to the suspension components.
Old 06-27-07, 11:27 AM
Jstunner56
Jstunner56's Avatar
thanks, ill looking into replacing the bent wheels. The tires are actually just a couple months old.
matts6887
08-15-22 01:58 PM
cmotomn
06-12-09 10:04 AM
girlilove
09-21-07 04:34 AM
slowtan
Suspension and Brakes
03-25-02 10:47 AM
Trillion2001
14
09-06-01 01:38 PM
Quick Reply: Steering Wheel Shakes please help
