DIY Fender Rear Shave
Old 04-26-07, 12:39 PM
carbongs
carbongs's Avatar
Originally Posted by milky
nice little write up! I didnt know the dremel wheel was strong enough to cut through the car fender
nice way to save $100 or so..
thanks, yeah it saved me a lot of money.
thanks gottagitmines!
Old 04-26-07, 12:42 PM
o2GS43o
o2GS43o's Avatar
Nice write up
Saiji
Saiji's Avatar
Awsome write up man!!!!!!!!!!!
Old 04-26-07, 12:44 PM
carbongs
carbongs's Avatar
thanks guys, really feelin the love. i just wish other would do more of this on little things that we all need or want to do but don't know how. just trying to help out because it took a lot of research to see how this was done. props to the DIYers!
Old 04-26-07, 02:20 PM
4ntvings
4ntvings's Avatar
perfect diy write up.
i'm actually surprised you rub at that height. eibach's will only drop about 1" all around-its a more conservative spring. GL!
Old 04-27-07, 08:48 AM
carbongs
carbongs's Avatar
i rubbed cause we had 3 porkers and a half in the car! lol
Old 04-27-07, 09:55 AM
bluelex
bluelex's Avatar
LOL...LOL
Nice job man. I hope you drop that thing low once your suspension comes it..
Old 04-27-07, 03:38 PM
nanotech
nanotech's Avatar
I don't know how relevant my question is to this thread.
I will be getting some rims.
here are the specs on them:
Rim Width: 8.5J
Rim Diameter (inches): 20
Offset: 35
Number of Bolts: 5
Bolt Pattern: 5 x 4.50 or 5 x 114.3
I have the car on L-Tuned springs now, will there be any rubbing or fittment issues? I currently have vibration problems and will it get worse or go away?
I am also getting hubrings, that should reduce vibration if any, have you guys experienced this? Any help would be much appreciated!
thanks
Old 04-27-07, 03:48 PM
shern
shern's Avatar
Wow! You did that whole thing with a dremel! Good writeup!
Steve
Old 04-27-07, 07:55 PM
carbongs
carbongs's Avatar
Rim Width: 8.5J
Offset: 35
Number of Bolts: 5
thanks
most vibration can be taken care of by on and off car high speed balance. the hubcentric rings should do the charm. make sure there are not any cracks in the existing hub rings either. also, check on your torque levels for the lug nuts. i check mine every 250 miles and torque them down to 85 lbs
Old 04-27-07, 07:57 PM
carbongs
carbongs's Avatar
Steve
thanks steve!
Old 04-27-07, 08:42 PM
KevinGS
KevinGS's Avatar
Nice job!
Great write-up.
Hmmm.... a dremel. I think I can, I think I can...
Old 04-27-07, 08:46 PM
antbo
antbo's Avatar
damn!! thats a super fat tire in the rear.
Old 04-28-07, 04:50 AM
sleeper408
sleeper408's Avatar
Nice write up! I only needed to shave mine up to the bolt holes, but I am running 275/30. Also, there is no rubbing partly because of the involuntary negative camber.
Old 04-28-07, 06:40 AM
slickgt1
slickgt1's Avatar
That is a nice write up. Car looks great by the way. I am curious, where did you get the eye lids, and those headlight rings. Thanks again.
Quick Reply: DIY Fender Rear Shave
