Gauge needles not working and no lights on buddies GS300?
Old 10-18-06, 02:24 PM
tmf2004
5% Club. Killing it!!!
tmf2004's Avatar
Default Gauge needles not working and no lights on buddies GS300?
My buddie has a 2000 GS 300 and his Gauges and dash lights stopped working yesterday after he wiggled the battery cable he told me.. Any ideas ? fuse, short, etc... He said the car had trouble starting so he messed with the battery cable and than the car started?
Tony
Old 10-18-06, 02:35 PM
chuckb
chuckb's Avatar
tell him how to reset ecu and it should be fine. he needs to check the battery connections too.
Old 01-10-07, 06:10 AM
LexySC300
LexySC300's Avatar
What is the ECU? My temperture gauge needle went out and I'm trying to figure it out.
Thanks
Old 01-10-07, 03:46 PM
17gs400
17gs400's Avatar
tell him to disconnect the negative battery terminal, its should reset everything. And gauge should light up again. Ihad the same problem, freaked
me out for a lil bit
Old 01-10-07, 07:05 PM
sabciu
sabciu's Avatar
Speaking of Gauges, on the 2000 GS's the needle is not lit, correct? The gauges are backlit, and they are somewhat dark at night for some reason. I tried the brightness adjustment but then the radio gets overly bright!!
Old 09-07-13, 10:28 PM
daddyduke
daddyduke's Avatar
just changed my ps pump and thi s just happened.i was about to cry until i red this post.lexus cars are the ****
Old 09-09-13, 09:09 AM
YxUxMADDDD
YxUxMADDDD's Avatar
remove connection from battery for an hour (or a day - from posts on CL) should reset the whole car and check all fuses. he probably made contact with terminals to the car. pretty sure he left that part out =p
JGWentwrth
09-17-18 04:30 PM
skpark70
SC- 1st Gen (1992-2000)
10-30-07 06:48 PM
erftimmeh
01-20-06 03:19 PM
17gs400
10-24-05 06:12 PM
HI98GS
03-30-02 05:10 PM
Quick Reply: Gauge needles not working and no lights on buddies GS300?
