strange rear thumping noise in 98 gs
car is a 98 gs400
I notice a clunk, thump noise in the rear area compartment. Sounds like its coming from the rear deck. Sounds like my spare tire is loose or my jack but it is NOT. Everything has been removed from rear trunk area but noise is still there. This happens when I'm going over bumps and especially driveways on a 45 degree angle (uneven grounds on one side of car)
Please help!!
Please help!!
Sput, I have the EXACT same problem. And I've done all the tests you have done as well, completely emptied the trunk, and I'm still getting the clunk over dips and bumps....and it's gotten worse over the last 6 weeks.
So enough is enough, I'm having it diagnosed next week. I'll let you know what mine was...I just hope they can find it. My hunch is that it's a bad bushing or shock in the rear.
KevinGS: Thanks for chiming in. Just another reason to love this forum.
Please do keep me posted. .
Do you have an aftermarket suspension? How about an aftermarket exhaust? I have the Tein CS and the Daizen Sways. And I have a Tanabe exhaust.
My hunch though is that it's a bad bushing or something in the suspension itself, I doubt it's the Teins...because I would imagine others would maybe have this same problem over time. My noise is certainly underneath the car, not up near the rear deck (as you mentioned). We might have different clunks. LOL
My clunking can be quite loud, especially if I hit a bump when going around a turn. Most bumps cause it to happen though, and most dips too...but if I go slow I can avoid the clunk. Like if I sloooowly creep over a speed bump, it won't happen. Driveways at any angle don't cause mine to clunk since I'm already going real slow....it's mostly bumps and dips that cause it at speeds above about 25-30 mph, where the car swings back on the rear shocks, and then CLUNK! But since small bumps cause it to clunk too, I know it's not the shock bottoming out. Hmmmm... We checked the exhaust, and it SEEMS that this is not the culprit (though we probably should have just removed the Tanabe exhaust just to be SURE, but we didn't). We did empty the entire trunk, including spare...still clunked.
So now it's officially a mystery. But it's gotta be something in the suspension, or maybe the oversized exhaust (doubtful). There's a teeny chance it's my L-Sportline rear bumper, but that's even more doubtful since it seems to be well installed with no movement.
Anyway, PM me if you haven't heard anything by Wednesday. I'll be busy next week so I may not remember to report the news in this thread...
KevinGS, since you mentioned teins cs with daizen sways, I've been getting the clicking/clunking sound over the bumps and dips in the front and was noticeable after the daizen sways installed.
I had everything tightened up: sways, struts, checked out all suspension components...
The only thing that seemed loose and had some play were the dinky endlinks.
I might have that changed out since my car is at about 140k miles.
Sput's problem is in the rear though, again check for the struts.
schmoozer
19
10-24-12 08:43 PM
