Broke your ABS/VSC sensor? Here's how to fix it!
Old 08-08-08, 11:32 PM
kit cat
kit cat's Avatar
Originally Posted by GSteg
You need to remove the a bit of the fender liner (towards the front bumper) . Once you have that opened up a bit, you'll be able to see the connector.
as always, you da man!
Old 02-03-09, 11:33 PM
LyFeWoRx
LyFeWoRx's Avatar
great write up. I'm checking this out.
Old 03-28-10, 01:26 AM
sam430
sam430's Avatar
Mine just broke... installed the TRD the wrong way. Well, the person who fixed my car installed the oem sway wrong and I referenced it.
Can I find out which side is broken using the code reader?
Old 03-28-10, 02:17 AM
BichoteGS
BichoteGS's Avatar
yea code reader will tell you witch side theres a different code for each side.C0200 is RF
C0205 is LF. I kno i have both lol. Im having codes for both but the left front is reading wheel speed fine. Its weird. anyone had this problem?
Old 03-28-10, 05:38 AM
shoeshine
shoeshine's Avatar
great write up. thanks for sharing
Old 03-28-10, 06:59 PM
sam430
sam430's Avatar
I wasn't able to pull the code. I guess I will manually test it. Ah, will finally buy a multimeter.
UPDATE: Well, what do you know, I hit a small bump and the light vanished. I pressed the vsc buttons and it's functioning again. The question:
Did the bump loosen the connection or did the sway loosened it? Both caused by bump. The reason I'm asking this question is because I don't want to switch the sway and end up pinching the line. Ahhh... another weekend, another one on one, with my car. Gotta break of this relationship and buy me a corolla.
Old 03-30-10, 05:07 PM
_TsK_
_TsK_'s Avatar
how much would u charge me if i send my abs wire to u to fix?
Old 03-30-10, 05:32 PM
vwynn
vwynn's Avatar
Jeff get the pics back! lol CL NEEDS IT :]
Old 03-30-10, 08:37 PM
JeffTsai
JeffTsai's Avatar
lol. The hosting on that website expired. I didn't even think anyone went on that site so I didn't bother to renew the hosting this year.
Old 03-31-10, 11:05 AM
sakataj
sakataj's Avatar
all i can say is photobucket.
but i know whatca mean jeff, when i reorganized my servo pics i didnt wanna move them as i would have to redo the pics and i got more important things to do lol
Old 03-31-10, 04:24 PM
sam430
sam430's Avatar
mine currently sitting. I bent the bracket temporarily so the sway doesn't hit it.
Old 03-31-10, 05:03 PM
vwynn
vwynn's Avatar
umm you sure u installed the sways correctly or u installed it backwards? lol.
JeffTsai
JeffTsai's Avatar
Sam, your sway bar is upside down lol. It should be a good 2-3 inches away from the ABS sensor if installed the right way. Yes, the sway bar can go in upside down and it will bolt right up, but it will sever both of the abs cables as soon as you hit a bump
Old 03-31-10, 05:07 PM
Anthony
Anthony's Avatar
lol.......thats pretty crazy that it will fit upside down.
Old 03-31-10, 05:10 PM
sam430
sam430's Avatar
LOL, yeah, I said temporary fix. I will flip it the other way around. The guy who worked on my car put it back wrong. I used it as reference when I put the TRD blue on.
This weekend, I will work on it. The good news is, the wire is not damaged. Thanks guys.
And for people hearing sounds of metal to metal when hitting a bump, well, check your sway to see if someone installed it incorrectly.
Quick Reply: Broke your ABS/VSC sensor? Here's how to fix it!
