NE1 know how to program a Keyfob on a 2002 GS?
I found an article for the pedal dance and it didn't work, but my key is not cut yet so I could not put the key all the way in....it should have be close enough to get a signal.........
This is what I tried........ but I wait 2 or 3 min and the light still flashes...
Lexus key programing
Insert working master key in ignition, within 15 seconds press acceleration pedal to floor 5 times, within 20 seconds press brake pedal as far as it will go 6 times. Remove master key. Insert new key in ignition but DO NOT TURN. Press acceleration pedal one time adn release. Security lamp on dash will blink for 60-80 seconds. When lamp goes out, key is programmed. Press brake pedal one time to exit programming mode.
