Water in Intake box
Old 07-11-06, 07:11 PM
usmarines
usmarines's Avatar
Default Water in Intake box
It was raining pretty bad in Kansas City and I hit a flooded area with out knowing and the water came up to my grill, I opened my air intake and the filter is wet and their is water inside of it, what should I do? What steps should I take?
Old 07-11-06, 07:54 PM
house66
house66's Avatar
Default Should be alright......
Hey man,
First let me say thanks for your service.
Regarding your question, If the car is running well I would just replace the air filter and call it good. Better yet put a K&N drop in filter. You are not having any issue with your car missing or sputtering correct?
Cheers,
House
Old 07-11-06, 08:10 PM
chuckb
chuckb's Avatar
buy a new oem filter and dry out the air box.
btw-here's what could've happened. https://www.clublexus.com/forums/sho...=water+flooded
Old 07-11-06, 08:27 PM
usmarines
usmarines's Avatar
Thanks guys, unlike the other member I didn't drive into it the traffic stopped because of the flooded area ahead and I was stuck in traffic couldn't back out in just a little while my car was surround and luckly traffic started backing out.
Old 07-12-06, 08:41 AM
Tammy
Tammy's Avatar
A Toyota dealer should be able to match the part number on your OEM air filter. It'll be a few dollars less for the same filter from Lexus.
If you get a check engine condiction, a dry off of the MAF sensor just downstream from the air filter box may be in order... gently with a Q-Tip.
Old 07-12-06, 02:13 PM
ksu1998
ksu1998's Avatar
drain it out. get a new filter. they are $19 at parts stores around KC area
I was in the same storm, it was a strange color in the sky.
D
Old 07-12-06, 08:21 PM
tonysofly
tonysofly's Avatar
dry everything out before you drive. water/air/gas is not a good mixture for combustion.
Old 07-12-06, 08:25 PM
chuckb
chuckb's Avatar
D
the $19 parts store filters are not cotton like the oem.
Old 07-13-06, 01:11 AM
PHML
Master Thread Closer!!
PHML's Avatar
Just hope no water passed the throttlebody...that would really mess things up.
Old 07-13-06, 05:12 PM
ksu1998
ksu1998's Avatar
You win I get mine from Sewell....but in the mean time he needs a quick fix.
D
Old 07-13-06, 05:32 PM
Bill_GS3
Bill_GS3's Avatar
If the car is running fine I would leave it. Unless the filter looks like it needs to be replaced anyways, the water will dry up. One method of removeing carbon build up from engines is to use water trhough the car. Something that should be done by a pro, I have locked one car in all the times I've done this at the dealer. Pretty strange thought but it works great.
-Bill
RickHansen
RC - 1st Gen (2015-present)
03-08-17 11:50 PM
BNR34
01-31-11 01:07 PM
tbilisi79
10-30-07 09:45 AM
ChronoJ1
Performance & Maintenance
07-01-04 12:48 AM
92Es300 5sPd
02-18-03 03:35 PM
Quick Reply: Water in Intake box
