DIY cabin air filter with LOTS OF PIX
Originally Posted by UberNoob
wow thats an awesome "mod"
Originally Posted by LEXUS_KID
Hey E-MAN I'll take 3 of those homemade filters I can even come by to pick them up
Originally Posted by IAGS400
E-man....You missed a step. First clean out your glovebox.
Originally Posted by chuckb
don't say that, now he'll change it back to stock
j/k...........nice job/info e
Originally Posted by e-man
Now, I do have one question. Can someone tell me which way the air flows through the filter? Based on all the crap that was stuck in the top of the filter, I assume it comes in through the top and flows down through the filter, but I'm not completely sure. If that's the case, you need to make sure the arrow on your filter indicating air flow is pointing down (I just realized that mine is pointing up and I'm going to have to redo it ).
e
e
Lexuskid - i've got 3/4 of that big filter left over if you want it.
George
does this actually work where you used a home filter and if it does what kind do u use or does it not matter. what i mean is do u use furnace filters or air purifiers filters. lowes has like all kinds.
http://www.lowes.com/lowes/lkn?actio...List&N=5000410
this is definetly a cheaper alternative than buying the actual oem filter
how to tell direction of air flow
e
e
with the AC on and set to take in air from the outside(recirculate mode off), pop in your hand where the AC filter was originally. You can actually feel the direction of air flow on your palm. I did this a few months ago so I can't remember but I think the direction of air flow should be from from top down. TRY not to stick your fingers into the channels above and below your palm since I'm not sure whether there are any rotating fan blades in those channels.
Originally Posted by aliti19
I did this DIY cabin filter last summer too. Great step by step instructions. Definately very easy to do. As far as airflow - all you gotta do is match up the arrows on the filter holder & the actual filter. (both pointing up).
George
George
And, on a related note, does anyone know why it even makes a difference? I mean, does the air flow better through the filter one way versus the other? The only thing I can think of is that it has something to do with the mesh support wires being on the opposite side of the way the air is flowing to make sure that a strong gust of air doesn't blow out the filter, but I'm not completely sure.
And here's the back side of it:
The top should be the white part of the filter and the open part of the frame.
The bottom should be the wire mesh of the filter and the cross pieces of the frame.
See my DIY thread for more: https://www.clublexus.com/forums/sho...d.php?t=122075.
Edit: My bad; I should have read the posts more closely. Per post 26, it is because you want the support on the side opposite the incoming force.
And thanks for the LT S/S props. Those compliments really make my day.
