heated seats problem
My heated seats stoped working the light does not come on =(. I checked the fuse under the glove box on the passenger side and it seems ok. Anyone experience this problem or know if there is another fuse somewhere ?
wierd
Very wierd one day I got in the car and it was of while the heated seats light was on. I checked all the fuses today and everything seems fine. Have you found a solution to your problem?
deniskags4...I have the same issue. No lights come on and no heated seats...fuses look OK...neither side works...have you or anyone else been able to figure out what is the typical cause here?
I know one side or the other is typical to fail with a busted fuse...but other than that I have no idea where to begin!
yeah, thought it would be easier to bump an existing thread instead of creating a brand new thread trying to rexplain the same problem...sorry for the confusion.
Where are these connectors and which center panel are you referring to? Do they burn out or go bad? I'm hoping it's a cheap and easy fix....
You da MAN NemeGuero!!!! Thanks so much!
So if I disconnect the positive end of the battery there's no chance in hell I could screw up the airbags, right? Any other things I should take note of while the battery is off?
