will a rmm intake off an is300 fit in a gs300
i was wondering if an intake of a is300 will fit on the 2nd gen gs, by visual everything looks perfect, just wondering about plugs......... and sensors.........
I don't know if the rmm off the is will fit the gs but I will say this...DON''T WASTE YOUR MONEY
on the rmm. When I had my gs300, I had the rmm intake installed. What a mistake. The stock gs300 is slow off the line and with the rmm intake, it was even slower. Once the car got going (above 3000 rpm) it was alright but but not much different from stock.
Master Thread Closer!!
Originally Posted by PHML
Intakes usually provide increases in higher rpm range.....and usually lose hp and torque at low rpm range. I guess you found this out the hard way.
now as for the IS to GS Intake... its the same engine with the same configuration... I dont see why it shouldnt work.
The One
You have a better chance if your car is a 01+. The way some of the tubing of intake are routed got changed slightly. The IS came out in 01 so the change was on both the IS and GS. I only know this because the PLP intake I have (which is FS BTW ) needed an extra hose and t-valve whereas it was bolt on for the 01+.
I have not seen the RMM intake so I cannot say for sure.
everything will bolt up.......... the only problem i ran into was that the car has an extra tube coming from the bottom of the frame.......... so the car requires three tubes while the intake only has two........ dont know what each tube does if it can be modified to work though
The One
This is what was done on my 98 to fit the PLP intake. Hopefully it helps you with your issue.
Neo is right, the 2000+ GS (the one with the engine cover) has a slightly different stock intake.
If yours a 98, then the IS300 one will like not fit. Trust/Greddy has made one for the GS300 98 - 00. PM me for more details.
