car doesnt want to start
Old 10-06-04, 09:22 AM
b1gredek
b1gredek's Avatar
Default car doesnt want to start
for some reason my car is having trouble starting, cranked really really weak a few times so i changed the battery, now it still doesnt start, kinda sounds like it might be the starter, i have to turn the key a few times before it starts, any suggestions, also we tested the power and it was on the weak side even with the new battery so it might not be the starter. anybody else have this problem, what were your symptoms of having a bad starter if it happened to you, also is it a diy project or too hard to do it at home. thanks
Old 10-06-04, 12:44 PM
Lexus GS3
Trouble Maker
Lexus GS3's Avatar
b1gredek : I have the same problem with my older lexus. Its the starter.. Get it replace and you're good again!
Old 10-06-04, 07:14 PM
rgarjr
rgarjr's Avatar
It is probably the starter. When the starter starts to go bad when you turn the key the starter just clicks. The starter on the GS300 is easy to pull out than the GS400.
Old 10-06-04, 09:09 PM
b1gredek
b1gredek's Avatar
hopefully in the next day or two ill be able to change it, thanks for the reply, let u know how it goes
Old 10-07-04, 06:35 AM
Woogie
Woogie's Avatar
starter or the starter cable.
Old 10-07-04, 08:45 AM
b1gredek
b1gredek's Avatar
what do u mean by starter cable, do i need to replace the cable or do i need to just check the connection on the cables to the starter thanks
AudioMan
RX - 1st Gen (1999-2003)
34
10-22-20 08:03 AM
SuicidnS13
Performance & Maintenance
11-02-10 08:51 AM
RICKLITE
05-10-06 04:43 PM
RA40
Maintenance
03-03-05 01:09 PM
airahcaz
Performance
04-25-03 01:19 PM
Quick Reply: car doesnt want to start
