Does it matter if I disconnect the - or + on battery to reset ECU??
Originally posted by NoRyceGS4
take off negative, but when you reconnect, reconnect with the positive first. disconnecting incorrectly can cause battery explosions. or so they tell us in autoshop, maybe just to scare us.
Master Thread Closer!!
Originally posted by SilverLexo
Always disconnect the positive. I'm sure removing the ground will have the same effect, but It's good practice to pull the positive, as that is ultimately what you are trying to do...disconnect the power.
Rule of thumb...if you not sure...don't reply to the thread.
Originally posted by Carpe Diem
...If the + is disconnected and somehow you bridge (say with an open end wrench) from any ground to the + terminal, BIG NASTY SPARK....
Originally posted by BuyERTS
I think that if you bridged any ground to the + terminal as you describe, you'd get a big nasty spark regardless of whether the + cable was connnected or not...
George
Read it again, not if the negative cable is disconnected. That's one of the reasons to disconnect the negative first!
George
George
Can't say that I'm less confused than before.
Just to be safe, I'm going to disconnect BOTH terminal.
(1) disconnect negative, push it out of the way
(2) disconnect positive, push it out of the way.
(3) cover both battery posts with the little plastic caps that came with the new battery
(4) after I'm done, connect the positive terminal back first
(5) connect the negative terminal back.
(6) done.
It can't get any safer than that, right?
